'dropped' Pitman Arm
Discussion in 'High Tech Retrofits' started by studsZ28, Oct 8, 2011.
  1. studsZ28
    studsZ28 Veteran Member
    115
    Feb 19, 2008
    MN
    Im in the process of swapping a LS1 into my 81 Camaro, and I ran across a issue with the Pitman arm contacting the alternator. I was able to locate a 'dropped' Pitman Arm but am wondering what idler arm and other components I need to keep the steering geometry correct. Ive read and found that I should be fine if I swap to the 79 Firebird set-up, But I found that there are two different idler arms... A shorter straight arm (measures at about 5 1/8" CC) or a bent longer arm (measures at about 6 1/8" CC).
    Im looking at MOOG for the steering components so having their part numbers would be great. Any and All help would be great!
    Thank you, Ben
  2. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Put 1/4" spacers under the motor mounts.
    You'll have to compensate for driveline angle change if it's a big change.
    Samething I'm doing with my 1970 442 LS swap right now to clear the steering linkage.
  3. Fbird
    4,048
    648
    Feb 12, 2011
    atlanta, ga
    search ..... steering box update.....cover all that stuff :)
  4. studsZ28
    115
    Feb 19, 2008
    MN
    Thanks, Ill have to keep looking. Thank you fbird.
    Thanks for the idea Aces, I just might have to do that. Just gotta make sure I have enough room in my trans tunnel. It looks a lil tight.
    Thank you both for your time,
    Ben
  5. JJFarmer
    JJFarmer Veteran Member
    2,447
    Jun 28, 2002
    Lenoir City, TN
    When I swapped to the drop pitman, I also change the idler to the different one to keep stuff in line. The car seems to handle quicker but that may just be in my head.
  6. studsZ28
    115
    Feb 19, 2008
    MN
    What idler arm did you use? Any measurements on the length? Is it straight or does it have a drop as well?
  7. Protour-Camaro
    Protour-Camaro Veteran Member
    2,111
    Feb 16, 2012
    California
    Did you keep the stock camaro drag link? They are expensive...Might as well find a Corvette pulley system if I need to swap that out too...It would be cheaper
  8. Protour-Camaro
    2,111
    Feb 16, 2012
    California
    After all my searches....I couldnt find any difference between the DS883 and the DS829, except the 883 was a V6 link for Camaro and V6/V8 center link for early year F-birds....
    Does anyone have pictures???
  9. JJFarmer
    2,447
    Jun 28, 2002
    Lenoir City, TN
    I only swapped the pitman and idler out, I used my Camaro center link with the TA stuff
  10. 1971CamaroGuy
    3,764
    161
    Oct 31, 2004
