Dual Plane Manifold
Discussion in 'High Performance Modifications' started by Oldskool62, Mar 17, 2018.
  1. Oldskool62
    Oldskool62 Member
    51
    10
    Sep 29, 2017
    Hi All,
    I have a 1978 Camaro LT and want to put a duel plane manifold on it. What I don't want to do is put a hood scoop on it so I want a manifold that I can use that I can use under the stock hood.
    Any idea's Thanks
  2. BonzoHansen
    19,618
    889
    Jun 1, 2005
    Scott from Hamilton, NJ
    A performer and and rpm performer will fit. an air gap should I think. a drop base air cleaner is needed for most
    Mwilson likes this.
  3. Twisted_Metal
    27,273
    1,107
    I used a Weiand Action Plus with a Q-Jet. (It's basically a Performer clone.)
    No mods and it fits under a flat, factory hood.
    Absolutely no extra space with the factory air cleaner... I have to be sure the wingnut is tight or the front edge will rub.
    No dents in the hood from it... just wore a little paint off.
  4. Oldskool62
    Oldskool62 Member
    51
    10
    Sep 29, 2017
    Thanks for the information. I am going with a 600 Holley and Chevy performance 14" airc leaner. don't think the Weiland is available any more though
  5. Gary S
    22,751
    900
  6. jvle95
    jvle95 Veteran Member
    202
    16
    May 14, 2007
    SF Bay Area, CA
    I have an RPM Air Gap with Holley 750 and drop base air cleaner. No issues. Its close but does not hit. Car is a 72.
  7. Ote
    Ote Member
    79
    11
    Sep 24, 2017
    Kennewick, WA
    I have an Edelbrock RPM Air Gap, Quick Fuel 780 carb and stock drop base air cleaner on my 1971. No fitment issues.
  8. Oldskool62
    Oldskool62 Member
    51
    10
    Sep 29, 2017
    Thanks Guy for the help it is much appreciated
  9. Patrick73RS
    Patrick73RS Veteran Member Lifetime Gold Member
    1,663
    59
    Oct 1, 2004
    Montreal (Living in Houston)
    Small block, Air gap RPM, holley 750HP and a drop base. No issues.
  10. silver81
    silver81 Veteran Member
    154
    Mar 8, 2008
    Western Wyoming
    remember too that you can mitigate hood clearance issues by selecting a shorter element to put in the housing. Wix has several different heights for the basic 14" round air filter. I have an air gap intake, edelbrock 1406, drop base and about 2 1/4 to 2 1/2" filter and all's well.
