Dual vs single muffler
Discussion in 'High Performance Modifications' started by 80sz, Oct 8, 2019.
  1. Jeep43
    Jeep43 Veteran Member
    1,282
    45
    Mar 30, 1999
    Connecticut
    Back when people were ditching the OEM transverse, there weren't any performance options for a transverse. Now Flowmaster and Pypes have performance transverse systems. The exhaust passes straight thru in perforated tubes with some wrap or stuffing in the main can. I don't see how the flow would really work against each other.
  2. 80sz
    80sz Veteran Member
    3,156
    415
    Feb 2, 2014
    Buffalo,n.y.
  3. 80sz
    80sz Veteran Member
    3,156
    415
    Feb 2, 2014
    Buffalo,n.y.
  4. Z28zz383
    Z28zz383 Veteran Member
    811
    11
    May 11, 2012
    Florida
    I'm making about 425hp and 450 tq. Right on the edge for going to 3'' pipes. Since the 383 is a torque motor I kinda kept the system smaller and set up for less rpm. I red line at 6k with the ZZ383. All I can say is it will sit you back in the seat, and things go by very quickly...Hahaha. People have told me it has a crack and snap sound to it when i'm getting on it. Get some compliments on the way it sounds at cruise in's.
    80sz likes this.
  5. Spoffie
    Spoffie New Member
    Jun 8, 2019
    The Pypes crossflow muffler uses the same exact design as a regular Race Pro, only it obviously uses 2 straight through tubes instead of 1. Same perforated tube design, same packing material as the regular Race Pro, only longer in length and mounted behind the diff. What's cool about Pypes though is that they give you different options. In addition to the crossflow, they offer both X-Pipe and straight duals with a choice of their 3 mufflers, or no mufflers so you can use whatever you like. Many people like to use the Dynomax Super Turbo mufflers with those systems.
    https://classicmusclecarexhaust.com/p/pypes-70-81-f-body-x-pipe-2-5-sgf11
    https://classicmusclecarexhaust.com/p/pypes-70-81-f-body-true-dual-2-5-sgf31
    https://classicmusclecarexhaust.com/p/2-5-dynomax-super-turbo-mufflers
  6. GoldenOne7710
    4,766
    377
    Jun 23, 2004
    Athens, GA
    As bad as I hate to...I'll throw the Flowmaster 80 series out there too. I have one on my car for ground clearance. It's actually not giving off much drone like FM is typically known for. My system was fabbed from scratch by a local exhaust shop from the headers to the tail pipes. I have no complaints. Fairly quiet idle and throaty when you lean on it heavy.
  7. 80sz
    80sz Veteran Member
    3,156
    415
    Feb 2, 2014
    Buffalo,n.y.
    Took off the 3” pypes system. Got the 2.5” on and butt meter says no difference. It’s almost same at idle but at 3000 much better. It’s not quiet but it’s not obnoxious. I like it and pretty happy. I think I’ll fab up a resonator tube next year to eliminate the vibrating/drone which also had dropped significantly .
    xten likes this.
  8. Z28zz383
    811
    11
    May 11, 2012
    Florida
    sounds good, resonators will knock it down some. I had thought about using the "hockey stick" tips that pypes sells and make a slip in resonator to fit in it for when I want it more quiet. Like on the interstate for long rides at 3000 r's.
    80sz likes this.
