Dyno tomorrow. guess my horsepower.
Discussion in 'The BS Topic' started by turbobuick, Jan 8, 2019.
  1. tom3
    tom3 Veteran Member
    11,310
    187
    Aug 1, 1999
    ohio
    I'd think even a lazy 454 tuned spot on should do 400hp and 400 tq, give or take 10 either way on both.
  2. RS1979
    3,220
    461
    Jun 18, 2013
    Memphis, TN
    What did you find out?
  3. turbobuick
    turbobuick Member
    51
    16
    Nov 24, 2018
    Going in alittle later today. You’ll be ther first to know.
  4. BLUE72CAMARO
    BLUE72CAMARO Veteran Member Lifetime Gold Member
    4,633
    129
    Mar 15, 2004
    Bunker Hill, IL
    I am going to guess 435hp and 460ft/lb.
  5. 1980RS
    1980RS Veteran Member
    2,312
    172
    Jun 17, 2006
    MN
    I will say 428hp and 485lbs. tq. with the Eddy carb and that cam. If you were to put a cam in there that is on a 108° LCA with a lift of about .550 and a good Holly 750 or maybe a Holley 850 I will then say 465hp and 510lbs. tq.
  6. turbobuick
    turbobuick Member
    51
    16
    Nov 24, 2018
    You win so far. It made 381 horsepower and 457 ft. Lbs. torque. He’s going to play with timing and try to get alittle more out of it tonight.
    jeff swisher and muscl car like this.
  7. 1980RS
    2,312
    172
    Jun 17, 2006
    MN
    How much timing did you put in the engine? and what kind of fuel did you test with?. My peanut port engine likes between 40 to 44° of timing with the low compression.
  8. RS1979
    3,220
    461
    Jun 18, 2013
    Memphis, TN
    New name for you Jeff. Jeff "The Horsepower Calculator" Swisher. LOL
    jeff swisher and turbobuick like this.
  9. turbobuick
    turbobuick Member
    51
    16
    Nov 24, 2018
    Played with timing. 34 degrees total
    Made 416 hp. And 504 lbs. torque!!!!
    jeff swisher and 1980RS like this.
