Dyno tomorrow. guess my horsepower.
Discussion in 'The BS Topic' started by turbobuick, Jan 8, 2019.
  1. turbobuick
    turbobuick Member
    51
    16
    Nov 24, 2018
  2. 1980RS
    1980RS Veteran Member
    2,312
    172
    Jun 17, 2006
    MN
    Much better, Here is what I learned on the low compression engines. These old BB like timing, I ran most of the day the first time out with mine at 36° and the car stayed in the low 12's. When I bumped it up to 42° the car went 11.90 with no other changes in 90 degree heat. With the single plane at the track it liked even more around 44° I had one like yours in the early 90's that had 51° timing and with a 600 Holley the car ran 11.63 @113mph with a single plane intake. If you do get to the track don't be afraid to bump it up more than what's on the dyno. I would also try a 750 3310 Holly also bet it make another 10hp or more. One thing I ran that day was an Eddy 800 Thunder carb, it worked very well. Congrats on your dyno test.
  3. jeff swisher
    jeff swisher Veteran Member
    587
    119
    Apr 26, 2018
    I was close on the first round.. Then you blew it out. Congratulations!
    Most will not even spend time or money on a dyno with a low HP deal.
    I kind of like it.
    I will be very curious if you stick it in a vehicle and test it on a wheel dyno as to what it will make.
    Not that it will see a wheel dyno.
    Should be a fun ride no matter what though.
    You picked up nearly 50 lb of TQ
    Don't tell me that was a timing only change that did that.
    Was the air intake temp in the dyno room cooler ?
    Was one corrected HP numbers?
    Did he use the same correction factors?
    What was timing on low HP pulls vs Hghi HP pulls?
    turbobuick likes this.
