ECM location
Discussion in 'High Tech Retrofits' started by badazz81z28, Jun 17, 2017.
  1. badazz81z28
    16,720
    464
    Las Vegas, NV
    wont fit where I wanted to put it. How sensitive to heat? Think it would. Be ok here?
  2. tom3
    tom3 Veteran Member
    11,945
    333
    Aug 1, 1999
    ohio
    Those things are pretty tough today, might actually be ok, but I don't like the location that close to the header pipe at all. Inner fender with a shield would be much better I suspect. Inside the car maybe near the same location as shown would be ideal, probably not possible though.
  3. badazz81z28
    16,720
    464
    Las Vegas, NV
    Man there just isn't anywhere with a flat spot to mount on the inside
  4. Randy 81
    Randy 81 Veteran Member
    930
    19
    Oct 28, 2009
    Loganville, Ga
    If you put a heat shield in place to block the radiant heat, it should be okay there.
  5. Goat
    1,905
    44
    Jun 7, 2001
    moncure, NC
    What if you mounted it in the same spot but higher? Who says it has to be a flat spot? Just put a spacer where needed...
  6. reedld
    reedld Veteran Member
    268
    Aug 9, 2007
    Painted Post NY
    Mine has been in that location for the past 7 years/11,000 miles. I'm in upstate NY so no where near as warm as Vegas....but I have not had any issues. I thought about possibly relocating battery and moving PCM up front.
  7. badazz81z28
    16,720
    464
    Las Vegas, NV
    I moved it a little higher, I'll show you where I put it
  8. budro6968
    budro6968 Veteran Member
    3,204
    507
    Apr 2, 2016
    Jax Florida
    I saw someone here put an aftermarket MSD box in the cowl section just above where you show it now. Would get air for sure but will rain hurt it?
  9. badazz81z28
    16,720
    464
    Las Vegas, NV
    It's gonna live here
  10. Turbo70Camaro
    2,146
    117
    Jan 7, 2005
    so cal
    Much much better, are you keeping the headers raw?
    house67 likes this.
