Eddy pro flow 3
Discussion in 'High Tech Retrofits' started by Cooldawg, May 10, 2018.
  1. Cooldawg
    Cooldawg Veteran Member
    196
    11
    Jun 3, 2014
    Angola, IN
    Anyone know if the pro flow 3 is compatible with the Z drop down dual snorkel air cleaner setup?
    The PF would sit lower overall than an Eddy AG manifold/ Holley sniper, but the throttle body has a smaller height dimension. Worried about throttle and/ or fuel rails causing a fitment problem with the snorkel.
    If the snorkel doesn’t work, it’s a show stopper; I’ll go with sniper or fitech with the RPM AG.
