EFI Comparison (MSD Atomic vs Holley Avenger vs FAST EZ vs Powerjection III)
Discussion in 'High Tech Retrofits' started by CDesperado, May 3, 2012.
  1. woody80z28
    5,572
    61
    Sep 8, 2004
    walton, ny usa
    WOW that is a lot of cam for EFI. What is your MAP reading at idle and under normal cruise?
  2. Rick WI
    Rick WI Veteran Member
    10,400
    Jul 9, 2001
    Madison, WI
    Doubt the cam is the reason. I run a 260/265 @ .050 and .700 lift roller on the street with a FAST system and never replaced an 02 in over 10 years. Does it carbon foul?
  3. newschool72
    newschool72 Veteran Member
    1,185
    Feb 25, 2011
    forsyth,ga
    Sounds like the Fast system might work better than the Holley system with an aggressive cam.:)
  4. 72 pile
    72 pile Veteran Member
    101
    Sep 16, 2003
    Woodland, Ca
    Ya it carbon fowels out. I don't remember what the map reads, I'll have to check tomorrow.
  5. 72 pile
    101
    Sep 16, 2003
    Woodland, Ca
    Ok finally got a reading on the map sensor.
    Idle-80
    Freeway cruse-55-60
