EFI people, what do you think?
Discussion in 'High Tech Retrofits' started by rocket dawg, Apr 8, 2018.
  1. UnseenZ28
    UnseenZ28 Member
    35
    Apr 29, 2015
    United States
    I've had Atomic EFI on 2 cars. great system. i'd recommend running a single plane intake with any system you choose though.
  2. Goodwrench1965
    Goodwrench1965 Veteran Member
    925
    41
    Apr 23, 2010
    Charlotte NC
    Why do you recommend a single plane?
  3. 76z28
    76z28 Veteran Member
    2,051
    51
    Jun 29, 2009
    bakersfield
    I have the proflo system. I love it. I just fiddle with timing and AFR--ran well enough to run an 11.3 the first time out on a street car that had never seen the track in about 5 years. This is with STIFF suspension and tuning issues(only self learned for the drive there!)
  4. UnseenZ28
    UnseenZ28 Member
    35
    Apr 29, 2015
    United States
    From my personal experience with the self tuning TBI systems they run way better on single planes. I just swapped to a single plane on my '79 with the Atomic and it runs way better. I think it has something to do with the divider on the dual planes not letting the map sensor get a correct reading. If you do a search on google you'll see people with similar results. Even Engine Masters on youtube did an Intake Shootout using FAST EFI TBI system and couldn't get it to run right on the dyno with a dual plane.
  5. rocket dawg
    rocket dawg Veteran Member
    334
    28
    May 5, 2015
    Grand Rapids Mi
    OK, got the car out last night after charging the battery. Fired right up, 5 minute warm up and on the road. Ran great, sounds great etc.. Stopped by by buddies for a cold one and smelled gas-again. Those dual feed blue and red flex ($$$) feed lines are leaking for the 10th time. Its time for the EFI system, I'm tired of fixing gas leaks and every time I tighten one area, a different one pops up. I'm going to Holleys tech line for some questions before I order, basically research the heck out of it. Looking at the single plane intake as well. If some of you are running a single plane, what brand?
  6. rocket dawg
    334
    28
    May 5, 2015
    Grand Rapids Mi
    Looking at the Torker 2 from edelbrock. Good choice? or not so much?
  7. CorkyE
    10,401
    483
    I have a Torker 2 sitting on the shelf - for a good reason. Poor design to begin with and has small runners. I'm going EFI soon and not even considering that manifold, going to use my RPM Air Gap. It has a notch cut down in the divider, giveing it a somewhat open plenum effect.
  8. rocket dawg
    334
    28
    May 5, 2015
    Grand Rapids Mi
    I have the same intake as you. Been hearing and reading all kinds of different theories/ideas etc. I wonder what is the best intake for a Sniper system. I have a question into Holley and should hear back Monday or Tuesday and i'll post there response. They know i have the RPM air gap installed now. What you say makes sense.
  9. wiseryder
    2,109
    49
    Sep 11, 2004
    belding,mi USA
    I dont have the sniper on my ride , the Fitech, using a RPM manifold, the thing runs great, so Im not to sure about the single plane theory myself
  10. czizza
    czizza Veteran Member
    1,028
    68
    Jan 8, 2004
    N. Massapequa, NY, USA
    I have the Edelbrock Proflo (original) it came with a Manifold that is like a Torker + RPM. I think it is similar to the Torker II. It is a raised open plenum (single) and I run a airhorn and port injection. Not sure if this helps your decision.
