EFI people, what do you think?
Discussion in 'High Tech Retrofits' started by rocket dawg, Apr 8, 2018.
  1. NotUniqueEnough
    NotUniqueEnough Veteran Member Lifetime Gold Member
    272
    15
    Feb 25, 2007
    Lost
    I installed a new 3/8 feed line and used the original feed line as a return
    My car didn’t have a factory return line
  2. 8pack
    2,622
    149
    Aug 29, 2007
    Western, MA
  3. Rickyb1968
    Rickyb1968 Veteran Member
    334
    17
    Feb 14, 2018
    Sub'ed for later when I go to EFI
  4. rocket dawg
    rocket dawg Veteran Member
    334
    28
    May 5, 2015
    Grand Rapids Mi
    Ok, my buddy bought the Sniper system for his SBC powered Jeep Scrambler. I pulled my air cleaner off and the unit fits with some minor mods. EZ enough. The "master kit" comes with the hoses, fittings, electric fuel pump, etc. I'd have to get some angle fittings just for added clearance, no big deal at all. $1259 plus tax from Summit Racing. The instruction sheet is very thin and we wondered where the rest of the instructions were. There is an online PFD file, we missed that on page one. So now everything is good to go. I have tons of reading to do for now, but this spring the Sniper system will be my project. I'll go with the black colored TB opposed to the gold unit. It will control the timing as well, so I have to mod the dizzy to some degree (still reading on that ) Any advantage/disadvantage to going that route? Like I said earlier, I have the 6A box and the MSD billet distributor. As far as I can tell, the fuel pump can go inline, close to the gas tank and high pressure hose going to the engine and a return line which I believe I already have. SO I'm kinda geeked to get it now that I know it will fit. I also get to help my buddy with his first so I wont be going into this totally blind. I'll keep posting with updates in the future. He has a cam change to do first, then the Sniper unit.
  5. need-for-speed
    need-for-speed Veteran Member
    698
    Feb 7, 2003
    Conroe, TX
    Interesting. So our carbureted cars came with a return line?
  6. CorkyE
    10,399
    480
    Not all did, my 79 Z-28 does have the return line. The return line was plumed into the fuel pump.
  7. redriderjf87
    redriderjf87 Veteran Member
    135
    12
    Jan 23, 2016
    Quad Cities, IL
    To that point, I was surprised to see my 81 Z did have the return line. I was wondering if it was because they had the computer controlled carb that year or something else. All that was already ripped out when I got the car other than the line.
  8. 76z28
    76z28 Veteran Member
    2,051
    51
    Jun 29, 2009
    bakersfield
    I used the charcoal canister return line, but being that I had a new tank I cut it and put it on the return section of the sender.
    0 issues with 3/8 feed with a 5/16 return
  9. BonzoHansen
    19,442
    798
    Jun 1, 2005
    Scott from Hamilton, NJ
    HD cooling cars got return line. AC, Z28 and such
  10. woody80z28
    5,572
    61
    Sep 8, 2004
    walton, ny usa
    I went Holley HP for ecm and wiring with my own components for manifold, tb, rails & injectors. I really liked the inputs & outputs and the ability to control nitrous and methanol with it. Everything I've read about Holley has been great. But mine isn't running yet because the car is in pieces.
