EFI pumps, what and where
Discussion in 'High Tech Retrofits' started by simso, Oct 27, 2019.
  1. simso
    simso Veteran Member
    415
    31
    Jul 10, 1999
    Australia Perth WA
    Hey folks,
    Going through the endless options of efi pumps, can anyone show me theirs and any issues with installation.
    i am aware of aftermarket efi and tank in one setup, but shipping to australia is a bit crazy price wise, other than holley is there any other direct fits, im okay with mounting one inline as well
    steve
  2. dave@ztech
    3,510
    719
    Mar 27, 2016
    NY
    I have read where some used the holley drop in to the original tank , and it was also returnless , so that makes it ever easier , hopefully they will post what they thought of it.
    buick skylark and simso like this.
  3. CorkyE
    10,451
    508
    Holley 12-304 is what I'm using with my ProFlo 4 setup, no problems so far. It seems to run 2 - 4 lb over the regulated 58psi but this has not been an issue.
    https://www.holley.com/products/fue...uel_pumps/muscle_car_efi_modules/parts/12-304
    buick skylark and badazz81z28 like this.
  4. simso
    415
    31
    Jul 10, 1999
    Australia Perth WA
    buick skylark likes this.
  5. simso
    415
    31
    Jul 10, 1999
    Australia Perth WA
    i actually pulled the mechanical pump out today, it had a feed line to it, but alongside it was another line that was blocked off, im assuming this is actually a return line to the tank, not totally sure on that but would be handy if it is, if it is i am guessing the replacement mechanical pump did not need a return
  6. CorkyE
    10,451
    508
    Yes, no return line required, I spoke with Eddy tech about this. The return is built into the pump.
  7. simso
    415
    31
    Jul 10, 1999
    Australia Perth WA
    Cool, how do you know its running more than advertised, have you got a pressure regulator installed as well?
  8. CorkyE
    10,451
    508
    Yes, the ProFlo 4 has a pressure sensor. No regulator installed, regulator is built into pump. Mine just runs a bit high.
  9. ErikNORCAL
    ErikNORCAL Veteran Member
    1,132
    11
    Aug 6, 2003
    now in VA
    OEM.
    5th gen camaro like a 2010 Camaro SS fuel pump should be available there for a similar global platform?
    Fabrication is probably available there but vetteworks sells the mounting rings in both steel and stainless. The website isn’t that great.. hard to distinguish between 4th and 5th gen
    https://vetteworksonline.com/catalog/product_info.php?cPath=9_68&products_id=235
    Might have to do a sump to get minimum depth. Run 3 bar fuel pressure regulator, he sells those too. The regulators are out of a vw or common euro model, again probably a global platform.
    buick skylark, simso and reedld like this.
  10. badazz81z28
    17,138
    553
    Las Vegas, NV
