EFI pumps, what and where
Discussion in 'High Tech Retrofits' started by simso, Oct 27, 2019.
  1. Zoomin
    Zoomin Veteran Member
    102
    24
    Aug 5, 1999
    Oklahoma City, OK USA
    Here's a quick pros/cons for each type:
    Inline pros: Easy to get to in case of failure, least cost.
    cons: has to be mounted low because they need to push gas, not pull it
    is noisier, tend to overheat, need a pre-filter
    in tank pros: Cooler, return and vent fittings are integrated,
    cons: more complicated to plumb, have to drop tank unless you've cut an access,
    Probably need a new tank. expensive
    Holley all-in-one pros: Use your current tank, use your current feed line, no return
    cons: connection to current feed line is not optimal for high pressure,
    Have to drop tank unless you've cut access
  2. CorkyE
    10,435
    504
    I don't understand that one. I used efi rated rubber hose and clamps, made connections just as you would with factory system. No leaks. Was one of the easiest parts of the install.
  3. Zoomin
    102
    24
    Aug 5, 1999
    I said not "optimal", not impossible. Clamps are more likely to fail thanpush lock, NPT or AN connections.
    buick skylark likes this.
  4. 76z28
    76z28 Veteran Member
    2,052
    51
    Jun 29, 2009
    bakersfield
    This can be remedied. I used pushlock on my car.
    I flared them fore 3/8 brake line fittings, and put on an pushlock adapter from the hydraulic store. Used pushlock hosing and I was done.
    I use the stock steel lines.
  5. Zoomin
    102
    24
    Aug 5, 1999
    That's better than using a clamp, for sure. It would have been nice of Holley to provide a fitting for that or nearly anything else. Too bad, because it's a really nice piece other than that.
  6. CasperCasper
    CasperCasper Veteran Member
    1,071
    176
    Aug 11, 2015
    Cheapest and easiest: get the corvette filter pressure reg assembly and run an inline pump, done.
  7. reedld
    reedld Veteran Member
    268
    Aug 9, 2007
    Painted Post NY
    I’ve had both setups.external pump is loud...didn’t like it.
    I now have 4th gen fbody bucket installed in tank. No FPR, one line to front,quiet, no baffling.
    Used vetteworks mount-in a custom make recess to clear trunk.
  8. Fbird
    4,151
    693
    Feb 12, 2011
    atlanta, ga
    I installed a 4th gen bucket in mine as well ...solved my issue as my first set-up was pump on a stick....with no baffling or bucket, fuel pick-up was hit and MISS...
    pros..quite like OEM ...worked fine! used stock tank (I had already made new lines)
    con... drop the tank cut a hole.
