Elgin Cam Specs:
Discussion in 'Engine Topic' started by 455 Formula, Jan 28, 2011.
  1. 455 Formula
    455 Formula Veteran Member
    1,421
    Dec 8, 2009
    Fresno, California
    I found an Elgin E274S in storage. I thought this must have been a solid lifter version of a 327/300HP camshaft, but cannot recall. Anyone have the valve events on this????
  2. hhott71
    hhott71 Veteran Member Lifetime Gold Member
    14,375
    Mar 30, 2001
    Joplin Mo. 64801
    929 cam used in 283-400 in 60's-70's
  3. 455 Formula
    1,421
    Dec 8, 2009
    Fresno, California
    Hey, Thanks guys!!!!
    Funny thing is, Elgin shows 3 different LSA's for the same camshaft!!!!!!
    Just found another mystery cam in storage up on top the compressor room!!!!
  4. 455 Formula
    1,421
    Dec 8, 2009
    Fresno, California
    The specs for this cam are all over the place...
    The most consistent specifications I have found indicate 258°/269° SAE, 194°203° @ .050" and valve events of IO @ 10° BTDC - IC @ 52° ABDC - EO @ 68°BBDC - EC @ 6° ATDC.
    However, the same chart shows the camshaft havingf 90° of overlap and shows the installed position of the camshaft with the intake at 110° and the exhaust at 122° respectively.
    When I plug the numbers into my cam program, assuming a 112° with the ICL @ 110°, I get events at .050" of IO @ -12.5° BTDC - IC @ 27.5° ABDC - EO @ 35.0° BBDC - EC -13.0° ATDC and MINUS 25.5° of overlap!!!!!
    This just isn't adding up in my head.
    Any thoughts????
  5. 455 Formula
    1,421
    Dec 8, 2009
    Fresno, California
    With only .398"/.420" lift, could we run 1.6 rockers on this without cutting the slots????
  6. Kamikaze
    Probably not even though it is a low lift / duration cam
    1.6 rockers move the pushrod closer to the inside of the slot/ hole and rub against the casting
  7. 455 Formula
    1,421
    Dec 8, 2009
    Fresno, California
    Yeah...I hate to grind on the heads as they are fully assembled...
  8. Kamikaze
    Just get a couple of Louis Tools and some sharp Cobalt bits, lube them up well then cover the engine valley with some towels and use a shop vac while you drill and you should be fine.
  9. 455 Formula
    1,421
    Dec 8, 2009
    Fresno, California
    Hmmm....how much lift would we gain???
