End the ox cart ride
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by John L. Roberts, Jul 7, 2019.
  1. John L. Roberts
    John L. Roberts New Member
    Jan 9, 2017
    Want to soften the ride on my 79 Z28. Has anyone changed their suspension to be firm, but eliminate the bone jarring stock ride. Suggestions?
  2. 79T/Aman
    79T/Aman Veteran Member NastyZ28 Sponsor NazstyZ28 Sponsor Lifetime Gold Member
    2,407
    102
    Oct 7, 2004
    Dickson TN.
    these cars were under sprung from the factory, and often times you will bottom out, pinion hitting the snubber, lower arm jounce bumpers, bad shock valving, firmer springs and better controlling shock valving is what is needed.
  3. xten
    xten Veteran Member
    2,456
    1,239
    Sep 24, 2014
    Pittsburgh, Pa.
  4. John L. Roberts
    Jan 9, 2017
    xten likes this.
  5. xten
    xten Veteran Member
    2,456
    1,239
    Sep 24, 2014
    Pittsburgh, Pa.
    Thanks!
  6. C4Racer
    C4Racer Veteran Member
    539
    99
    Oct 26, 2018
    I have hotchkis and Bilstein all around on mine - it's pretty well balanced.
  7. John L. Roberts
    Jan 9, 2017
    Thanks C4,
    I've heard from other Hotchkis fans and will go with those.
    Thanks again,
    John
  8. dcozzi
    dcozzi Veteran Member
    2,716
    219
    May 1, 2002
    Phoenix, AZ
    If you have KYB shocks, changing them out with a better one like Bilstein will help.
    You can use a softer spring with a larger sway bar and still handle well with a smooth ride.
  9. C4Racer
    539
    99
    Oct 26, 2018
    +1 to the shock upgrade. I had KYB's on my car w/ the Hotchkis springs when I got it and changing to Bilsteins was a huge improvement all around - handling, control as well as ride quality.
  10. John Wright
    14,591
    185
    Aug 9, 2002
    Rustburg, Va
    Smooth articulating joints [ie. bushings in the control arms and leaf springs] help with the ride. You may think that factory rubber bushings would absorb harsh jolts, but they actually add to the spring rate. A smooth, greased, delrin or other hard material will let the suspension cycle smoothly and actually let the shocks and springs do their jobs more efficiently then the harsh jolts get absorbed.
    Just for kicks, next time you have the suspension apart, try moving the upper and lower control arms with rubber bushings in them by hand. My greased delrin bushings move effortlessly and act like bearings more than bushings.
    Just a few thoughts......
    C4Racer, G72Zed and dave@ztech like this.
