Engine overspray
Discussion in '1970 - 1973 Specific' started by 1972original, Feb 13, 2020 at 12:01 AM.
  1. 1972original
    1972original Member
    56
    Oct 30, 2018
    Does anyone have a picture of the engine overspray onto manifolds and houses for 1972 camaro? Thanks for any infirmation.
    Bill
  2. budro6968
    budro6968 Veteran Member
    3,336
    543
    Apr 2, 2016
    Jax Florida
    What do you mean by Engine over spray? If you get paint on the exhaust manifolds it will likely burn off on the first start up.
  3. 1972original
    1972original Member
    56
    Oct 30, 2018
    I was asked by the restoration shop if I wanted overspray on manifolds and hoses? I don’t know if they have a special paint.
  4. budro6968
    3,336
    543
    Apr 2, 2016
    Jax Florida
    IDK about that. I would think that the engine was painted prior to installation. I would not want it but someone might know if that was a thing at the factory.
  5. xten
    xten Veteran Member
    3,072
    1,837
    Sep 24, 2014
    Pittsburgh, Pa.
    I've seen it on "correct" restos, even on original cars. Usually pretty obvious on aluminum intakes
    budro6968 likes this.
  6. Dan Videoman
    Dan Videoman New Member
    13
    Nov 16, 2019
    I have it on my 72. Let me get a pic.
  7. 1972original
    1972original Member
    56
    Oct 30, 2018
    That would be great as mine is a 72.
  8. 70lt1z28
    3,471
    689
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Tonawanda or Flint engine?
    If I recall correctly, the overspray on exhaust manifolds happened on Tonawanda small and big blocks starting in 1965. Small blocks built at Flint (including SHP Z28 engines) did not have the exhaust manifolds attached until after paint. The intakes were on with plastic covers over them. Varying amounts of overspray were around the edges depending on who had the gun and how he felt that day. This is for a 69, but the procedures didn't change for 72:
    http://www.camaros.org/forum/index.php?topic=907.0
    another good read:
    http://www.camaros.org/forum/index.php?topic=11414.0
    The bellhousing got it also.
  9. 1972original
    1972original Member
    56
    Oct 30, 2018
    Mine was Tonawanda.
  10. Dan Videoman
    13
    Nov 16, 2019
    IMG_20200214_133139.jpg IMG_20200214_133139.jpg IMG_20200214_133203.jpg IMG_20200214_133139.jpg IMG_20200214_133203.jpg IMG_20200214_133139.jpg IMG_20200214_133203.jpg 1972 rd ss 350 auto
