Engine Paint ?
Discussion in 'Camaro Questions' started by AlyshaLeake, Nov 13, 2019.
  1. AlyshaLeake
    AlyshaLeake New Member
    Nov 13, 2019
    Hi,
    I just pulled the motor out of my 73Z to replace gaskets and detail the engine. I'm not sure what to do about paint, I want it to look stock and last. Should I use Duplicolor spray cans or what about POR 15 spayed out of my gun? What have you guys had good luck with? Primer,do I need it?
    Thanks
  2. dave@ztech
    3,475
    714
    Mar 27, 2016
    NY
    Hi, and welcome to the site, POR-15 does make an engine enamel , I have never used it, Eastwood has several products you can use some , rattle can and for sprayers, just make sure you use a good grease and wax remover first, and follow the directions , on the can, or the paint will not stay on long.
    buick skylark likes this.
  3. bodymanbill
    bodymanbill Veteran Member
    1,306
    666
    Feb 1, 2007
    South Park Pa
    Like Dave said make sure it’s clean as possible, I always spray a coat of epoxy primer first but not to thick then single stage urethane paint again not to thick just enough to cover. Let’s see that 73Z , obviously my favorite.
  4. John Wright
    14,700
    212
    Aug 9, 2002
    Rustburg, Va
    As for color...I like to paint my engines black. Any light seepage will attract dust and make it look dirty, and chevy orange finger prints up pretty bad, the black helps with that.
