Engine Power - 1973 RS Camaro build shake down
Discussion in 'The BS Topic' started by COPO, Jan 15, 2020.
Tags:
  1. Chevyforever
    Chevyforever Veteran Member
    668
    81
    Jan 4, 2011
    So I froze the view of the piston top and ran the part # of the MAHLE pistons, 4.185" bore
    John Wright likes this.
  2. jlsug
    jlsug Veteran Member
    304
    10
    Apr 10, 2012
    iowa
    world prducts did make ls hybrid Product Description
    World Products 084080 - Cast Iron Motown/LS Engine Block Chevy Small Block 350 Mains, 3.995 Bore, Nodular Caps
    World Products SBC/LSC Cast Iron Engine Block Chevy Small Block Raised Cam +.134" 350 Mains, 9.240"Deck, 3.995" Bore, Nodular Caps, 55mm Cam, .904" Lifters.(includes, Freeze plugs, Cam plug, All dowel pins and Pipe plugs) 084080
    For more detailed information click on the link below.
    https://www.billmitchellproducts.com/cast-iron-sbc-w-ls-heads/
  3. dcozzi
    dcozzi Veteran Member
    3,148
    446
    May 1, 2002
    Phoenix, AZ
    It was likely a 400 Dart block.
    I have never seen a Dart 350 block. Do they exist?
  4. badazz81z28
    17,108
    548
    Las Vegas, NV
    Can you even call it that? It’s a hybrid...you can get a 4.000 or 4.125 bore and it can accommodate so thing like a 4.100 stroke. Uses LS bearings etc...I don’t think they consider it a 350 or 400 block.
  5. dcozzi
    3,148
    446
    May 1, 2002
    Phoenix, AZ
    Don't know. It's not really a 5.3, 6.0 or 6.2 either. Unless you have quality genI stuff laying around, I do not know why you would build this particular motor. I think most would build one or the other. The modern top end seems to be the biggest, maybe only, reason.
    It says 350 mains in the description. I thought that indicated genI crank/bearings.
  6. badazz81z28
    17,108
    548
    Las Vegas, NV
    I don’t see a compelling reason to have this hybrid either unless you purposely want a big cube SBC but want LS heads. But you can always get killer heads for a SBC too...
    I rather buy a aftermarket LS block.
  7. muscl car
    21,793
    694
    Jul 8, 2001
    High Desert of Hesperia Calif
    Dart has both SHP and Little M blocks with 350 mains
    My Shafiroff 427sbc has a Dart block with 4.125 bore with 4.0000 stroke using 6" rods
  8. John Wright
    14,712
    215
    Aug 9, 2002
    Rustburg, Va
    If you already have SBC running gear all sorted out you may not want to swap all of that stuff back out to run an LS. That's where I am presently, I have the transmission, bellhousing, driveshaft and turbo exhaust all of that stuff worked out and really do not care to reinvent everything again to get an LS in there.
  9. dcozzi
    3,148
    446
    May 1, 2002
    Phoenix, AZ
    I would feel the same if I ever go turbo.
