Engine vin
Discussion in 'VIN, Trim Tag & Drivetrain Decoding' started by Dthirteen, Nov 20, 2019.
  1. Dthirteen
    Dthirteen New Member
    Nov 20, 2019
    Hello. Hope all is well. I have a chevy engine block with 3970010 on drivers side rear of the block and 155105T1T on the front passenger side below the head just behind where the alternator mounts. Is this a 350SB and what year?? Have not been able to figure out what 155105T1T decodes too??
  2. Gary S
    22,500
    783
    The 3970010 block is a 4" bore block. It was used on 327, 350, and 302 engines from 1969-1979. The 327 and 302 engines were one year only in 1969, so it pretty much can be assumed to be a 350 engine.
    Like you, I can't figure out what the 155105T1T is becuase it doesn't seem to match up with codes on any available list.
  3. 2ndGenCrazy
    2ndGenCrazy Veteran Member
    723
    33
    Aug 18, 2011
    Upstate New York
    Take an image and post it. Numbers don't make sense.
