enough charging capacity - 1 more amp
Discussion in 'Car Audio, Electronics & Security' started by Chuck71RS, Jun 10, 2019.
  1. Chuck71RS
    1,440
    178
    Nov 24, 2012
    Houston, Texas
    Want to add a third amp of 25 watts (+/-) per channel but don't know if the electrical system has enough charging capacity
    Alternator - 61 amps
    Electrical draw
    Stereo - 2 amps, 35watts (0.5% thd) per channel (140 watts max)
    Air Conditioning
    Wipers
    Lights - all LED except headlights
    headlights
    tac
    fuel gauge
    oil pressure gauge
    temp gauge
    Is there enough capacity?
  2. dave@ztech
    3,426
    712
    Mar 27, 2016
    NY
    will be interested in the answer, as I am wondering the same thing
  3. Coadster32
    1,632
    133
    Oct 2, 2013
    Milford,CT
    This may not give you a definitive answer, but here's a bit of fat to chew on. ( I'm not an expert by any means, so keep the mud slinging down please) :crazy:
    Watts=volts x amps....12volt system x 61 amp alternator = 732 total amps. (Some may say 14 volts charge, then you're 854).
    One thing I don't get is a 2 amp stereo with 140 watt capacity in a 12 volt car. That doesn't add up.:screwup: Probably has a 15 amp fuse.:smokin:
    You can try it, and see if you're headlights dim, (just like back in the late 80's). If they do, then just get a bigger alternator. No sweat.
    Chuck71RS likes this.
  4. Chuck71RS
    1,440
    178
    Nov 24, 2012
    Houston, Texas
    The two amps were after market Kenwood installed in 1986 but they still play clean. Both are connected to the 1986 installed Kenwood eq, which is connected to a modern head unit.
  5. rchydzik
    833
    22
    Nov 13, 1999
    Colbert, WA USA
    If your voltage is ok, you are fine. If the alternator cannot supply the amperage, the voltage will drop below 12 under high load and the battery will pick it up. Idle is where you might have a problem.
  6. Twisted_Metal
    26,988
    966
    It will be fine.
    Those amps are rated at peak power (usually shifted to one channel) then they multiply by four channels.
    I’m amping more than that with a stock alternator.
