epoxy prime cure time
Discussion in 'Body Restoration' started by grasmo, Sep 30, 2014.
  1. grasmo
    grasmo Veteran Member
    893
    Dec 21, 2005
    tallahassee, fl
    how long should I let epoxy primer cure before applying my filler? should I use the tech sheet time recommendation they give for topcoating as a cure time before filler?
  2. mgoad1971
    mgoad1971 Veteran Member Lifetime Gold Member
    2,472
    Jul 29, 2011
    Houston, Texas
  3. grasmo
    893
    Dec 21, 2005
    tallahassee, fl
    well, since there's no clear consensus and my tech sheets don't say anything about it, does anyone have experience spraying nason ful-poxy and applying filler? approx. cure time?
  4. mgoad1971
    2,472
    Jul 29, 2011
    Houston, Texas
  5. grasmo
    893
    Dec 21, 2005
    tallahassee, fl
  6. Dogwater
    Dogwater Veteran Member
    926
    Dec 23, 2010
    SanAntonio Tx
    Looks like over night.I sprayed a fairly heavy coat of epoxy. I wasn't worried about runs or OP just wanted to get it on. Usually theirs a 36 to 48 hr maybe longer window for good chemical adhesion, so you want to start applying the filler soon. I pretty much sanded a lot of the epoxy off from the outter edges of the filler, don't really have a choice about that, but I knew that I was going to spray another coat anyhow. I did spot in epoxy over the finished filler cause it will soak into the filler.
  7. 76_TypeLT
    6,389
    144
    Jul 26, 2008
    Houston, TX
    if the spec sheet does not help, I would call the tech support line and ask.
