epoxy primer/ self etch?
Discussion in 'Body Restoration' started by tims78camaro, May 23, 2018.
  1. tims78camaro
    tims78camaro Veteran Member
    590
    Aug 6, 2008
    louisville ky
    i epoxy primed bottom of my floor. when putting them in i nick a small spot. can i put self etch over the epoxy or what should i use untill i can undercoat them?
  2. jimrr
    jimrr Veteran Member
    1,332
    306
    Jun 12, 2016
    sarasota
    yes.
  3. mark wagner
    mark wagner Veteran Member
    2,129
    19
    Jul 31, 1999
    Saylorsburg Pa. USA
    paint them before you undercoat. epoxy primer will seal, but etch does not. etch prime is great stuff, but like regular primer is a sponge, and will absorb water, putting undercoating over it will just trap moisture and actually cause rust. even rustoleum is fine to seal the etch. just a note - don't put epoxy over etch, it will peel off in a week or two...
    76 camaro car 1 likes this.
  4. Huggerorange80
    Huggerorange80 Member
    34
    May 19, 2018
    Epoxy is superior.
  5. 76 camaro car 1
    76 camaro car 1 Veteran Member
    2,393
    Apr 23, 2010
    St.Augustine,Florida
    Thanks Mark. I learned something new today. I have about as many years as you in the field (40) and never knew not to spray epoxy over etching primer. I have never done it and will now make a mental note not to ever do it. Nice to learn something new without having to find out the hard way.
    mark wagner likes this.
