Excessive Blow-by on Fresh Engine
Discussion in 'Engine Topic' started by 71smalbloc, Jun 24, 2019.
  1. 71smalbloc
    71smalbloc Member
    55
    Jan 6, 2016
    Blacksburg, VA
    No detonation problems. Only other thing I can think of is the top end is a little noisy.
  2. 71smalbloc
    71smalbloc Member
    55
    Jan 6, 2016
    Blacksburg, VA
    I'll do that, thanks for the input!
  3. 71smalbloc
    71smalbloc Member
    55
    Jan 6, 2016
    Blacksburg, VA
    Block was hot tanked and honed.
  4. G72Zed
    G72Zed Veteran Member
    974
    207
    Sep 8, 2015
    A few questions for you 71smallblock.
    1- Are they the Gapless tops or 2nd ring.
    2- If the Gapless is on top, did your builder use or mentioned using the Total Seal "quickseat" in conjunction with Total Seals bore/hone prep recommendations??, was a TQ plate used to final hone, type of break in oil and how long was it used for?
    As far as a comparative, everything being equal, you will have better "cranking" pressure when tested vs a traditional top ring.
    If this checks out even in all cylinders (within reason), as mentioned, a leakdown is next, if the bore prep was done correctly, you will have great leakdown #'s as well, and there lies the conundrum.
    71smalbloc likes this.
  5. 71smalbloc
    71smalbloc Member
    55
    Jan 6, 2016
    Blacksburg, VA
    I'll definitely ask him these questions. I've had a "rebuilt" engine in the past (different builder) which was diagnosed with ring seating issues but that one consumed a lot of oil and smoked a good amount. This one hasn't consumed a drop of oil in 600 miles.
  6. G72Zed
    974
    207
    Sep 8, 2015
    Yep, some swear by them, and some swear at them.
    That's a good sign, but it's early, and depends how you drive it, you may be OK.
  7. 70lt1z28
    3,175
    605
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Head gasket might be blown into a the lifter valley. Possible but rare.
  8. Michael Sammy
    Michael Sammy Member
    73
    10
    Dec 23, 2017
    I had what I thought was blowby. Turned out the carb was sucking oil through the hose that ran into the breather of the valve cover.
  9. cadillac_al
    cadillac_al Veteran Member
    806
    75
    Apr 22, 2015
    Maine
    The engine builder is probably right. Is that 600 easy cruising miles? It is barely broken in. It's time to hammer on it a little and do some deceleration runs to seat those rings.
  10. 77 cruiser
    77 cruiser Veteran Member
    531
    23
    Nov 17, 2006
    Frostbite Falls MN
    Torque plate honed?
    CNC BLOCKS likes this.
