Exhaust manifold stuck on head
Discussion in 'Engine Topic' started by Justin Berke, Jan 12, 2019.
  1. Justin Berke
    Justin Berke New Member
    25
    Jan 11, 2019
    British Columbia
    Anyone know any tricks to un-stick stuck on exhaust manifolds?
  2. Justin Berke
    25
    Jan 11, 2019
    British Columbia
    Btw yes the bolts are off
  3. CorkyE
    10,010
    357
    Cast iron exhaust manifolds on iron heads? If you have all 6 bolts off per side, give them a couple good smacks with a heavy dead blow hammer and follow up with the pry bar treatment. Odd though, if they were installed with factory gaskets, they usually come right off.
  4. Green hornet
    Green hornet Veteran Member
    1,639
    274
    Oct 11, 2015
    North Bay, CA
    ^+1 has worked for me in the past.
  5. tom3
    tom3 Veteran Member
    11,612
    246
    Aug 1, 1999
    ohio
    A lot of these manifolds were put on at the factory with no gaskets, get rusted into the head. Give a good soaking first with loosener, then the above beat and pry.
  6. COPO
    17,232
    474
    Toronto, Ontario, Canada
    I still don't ever use gaskets on mine and the manifolds have been off several times.
  7. 1980RS
    1980RS Veteran Member
    2,813
    344
    Jun 17, 2006
    MN
    Do the same thing I do with stuck bolts, heat the area around the head and manifold where they meet then melt wax into it, hit it with a dead blow hammer and it should break free. I cannot honestly say I have ever had a manifold that would not come off with out the bolts, that's a new one on me.
  8. COPO
    17,232
    474
    Maybe someone welded it to the head.
  9. Justin Berke
    25
    Jan 11, 2019
    British Columbia
    I sure hope not
  10. nova75mike
    nova75mike Veteran Member
    347
    Mar 20, 2008
    Etters, PA
    dont laugh. I had someone do this on my 82 Camaro. gives a whole new meaning to "custom exhaust".
