F70 14 Modern Size
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Codeman71, Aug 20, 2019.
  1. Codeman71
    Codeman71 New Member
    13
    May 12, 2019
    What's the modern day equivalent tire size for the original F70 14 tires?
  2. Twisted_Metal
    27,049
    993
    215/70R14 or 225/70R14
    There's about 1/2" difference in height between the two sizes and 1/4" difference in tread width.
    The way a radial tire "squats" a bit on the car, I would go with the 225/70 to keep the overall size perception closer to the look of the F70/14.
    If you're mounting them on a 7" wide wheel. You at the maximum rim width recommendation for the 215/70-R14.
    (A 225/70R14 will be a better "fit" on a 7" wheel.)
