factory gauge swap and HEI
Discussion in 'Electrical Systems' started by Bills69, May 7, 2019.
  1. Bills69
    Bills69 Veteran Member
    118
    May 28, 2018
    how should the tach be wired up with HEI
  2. Twisted_Metal
    27,273
    1,107
    Are you swapping out an "idiot light" cluster for a factory gauge set? (U14 cluster)
    http://www.nastyz28.com/2gcog/tech/u14swap.html
    The dark brown wire in the #1 position of the plug goes directly to the "Tach" connection on the side of the HEI distributor.
  3. Bills69
    118
    May 28, 2018
    that is what I did for some reason the car will not start
    unplug it from the tach connection it starts right up
    took me hours to figure that out
    it is the brown wire in the number one slot
    note: instrument cluster is not installed yet
  4. hogg
    hogg Veteran Member
    3,168
    27
    Dec 29, 2000
    pegram,tn.,cheatam
    your most likely grounding out the other wire,connector at distribitor,the one beside the tac plug,,maybe
  5. Bills69
    118
    May 28, 2018
    thats what I figured
    will trace back
    thanks
