fan shroud, bbc
Discussion in 'Engine Topic' started by Jimmac, Jan 23, 2019.
  1. Jimmac
    Jimmac Veteran Member
    407
    82
    Dec 24, 2013
    tucson az
    just dropped a 454 into my 71 and of course one thing I forgot was a fan shroud. Anyone have any luck running a car without one? going with a fan clutch, motor isnt built, just a low compression 454 headers, intake.
    plan is to just finish the swap, basically belts, hoses, dist, carb. and ford solenoid. and see how it runs. jim
    1980RS likes this.
  2. ronzz572
    2,114
    104
    Feb 8, 2007
    imperial pa
    They do sell reproduction big block fan shrouds if you didn't know . Probably a good move to buy one and install it. Finding a OEM original is going to cost some serious money if you even find one. Possibly $1500 and up.
  3. Jimmac
    407
    82
    Dec 24, 2013
    tucson az
    I'm definitely going repop. nothing original about the car anymore. started out as a 307 powerglide when we got it in 78. now 454 th400 12 bolt.
    I just want to get the thing on the road asap. so I'm just going without a shroud until I order one. its go a big hole in the hood where the 6-71;used to stick out.
  4. 1980RS
    1980RS Veteran Member
    3,684
    702
    Jun 17, 2006
    MN
    Yes, I have a big radiator with my 461 and I use an electric cooling fan off a 98 Buick LeSare. It's a 2 speed fan so I can run it on low around the pits and have it on high when I need it. Engine runs 170 to 185° on a 90° day.
  5. bigbloc
    bigbloc Veteran Member
    546
    Feb 16, 2000
    Pittsburgh PA USA
    It depends which motor mounts you used. If you used later style clamshell mounts, you could use a 7 blade fan from a later 2nd gen and the heavy duty cooling shroud. I used my factory fan and shroud with my BB swap.
  6. Jimmac
    407
    82
    Dec 24, 2013
    tucson az
    went and ordered a oer shroud, the small block shroud is too thick and I dont want to cut it up in case the car gets a small block again someday. jim
  7. Jimmac
    407
    82
    Dec 24, 2013
    tucson az
    big brown truck showed up this afternoon. took about 10 minutes to install.
    even screwed a cowl scoop onto my hood. bbc with a rpm intake doesnt fit under a stock hood. next up, order a steel cowl hood. jim
  8. theflash
    11,040
    34
    Feb 27, 2004
    Podunk, CT
    I used the SBC fan shroud when I put a BB in my 71, I just needed to put in a 1" smaller diameter fan
