Fan switch? who dun it?
Discussion in 'High Performance Modifications' started by amschnellsten, Apr 25, 2009.
  1. amschnellsten
    amschnellsten Veteran Member
    210
    Feb 16, 2009
    cincinnati ohio
    I was wondering if anyone could tell me what fan switch they used for electric fans? I have mine relayed and switched already so I am looking for a temp switch for the intake. Has anyone just picked one from another car at autozone that would screw into the intake next to the thermostat?
  2. 79camaro2001
    4,769
    May 4, 2003
    Monroeville, PA
    I bought a temp switch that connect at 180*F from painless. wired it up to a relay and when the switch connect it turns the relay on and then it turns the fan on.
  3. Air_Adam
    Air_Adam Veteran Member
    I also have a Painless unit. Turns on at 200, off around 185. Works great.
    If you want an easy to find parts-store part, get one for a 3rdgen Camaro or Firebird with a V8. They turn on at something like 220 and off at about 210, but they still work just fine.
  4. 79camaro2001
    4,769
    May 4, 2003
    Monroeville, PA
    I got one that actives at 180* cause here in Texas the heat can be pretty high. Rather have the fan running then letting the motor get too high. But up North this might not be too big of a problem
  5. amschnellsten
    210
    Feb 16, 2009
    cincinnati ohio
    I do not need the painless set up. I have wired in a nissan relay box to the low and high speed fans to my arch controller. I want to put a temp switch inline to the low speed fan in the manifold and was wondering if anyone has done the same? If so what temp switch did you use and can I just pick one up at an auto parts store?
  6. tom3
    tom3 Veteran Member
    10,485
    26
    Aug 1, 1999
    ohio
    From the third gen boys:
    Here is some information on the various cooling fan switches made by GP Sorenson that should screw right in. At least the pitures on the advance auto parts and napa site look like it. Hope this helps someone.
    Part Number Closing Temperature
    FS1............................222-238
    FS3............................240-252
    FS4............................211-227
    FS6............................204-220
    Also, put the switch in the head for a quicker turn on if needed.
  7. amschnellsten
    210
    Feb 16, 2009
    cincinnati ohio
    Perfect, that is exactly what I was looking for.
  8. gordonquixote
    3,021
    Jul 18, 2006
    Tallahassee, FL
    Don't use the temp relay from Summit/Jegs. I've burned two into the 'permanently on' position within 5 minutes of the car warming up.
  9. yodaddy
    yodaddy Veteran Member
    150
    Apr 28, 2004
    cumberland, md
    I couldn't get "FS" to cross over. Is it safe to assume that a BWD brand TFS1 is the same as a GP FS1?
  10. amschnellsten
    210
    Feb 16, 2009
    cincinnati ohio
    Does anyone know of a lower temp switch than these
