Fast EZ-EFI 2.0 Engine Control Kit - New in Box
Discussion in 'Swap Meet Section' started by twil, Mar 9, 2018.
  1. twil
    twil New Member
    16
    Aug 22, 2006
    Chicago, IL
    20180227_01.jpg 20180227_040152.jpg 20180227_040220.jpg 20180227_040246.jpg 20180227_040341.jpg This kit was purchased and never used. I planned to do an LS Swap. Completely Brand New and still in sealed package. Prices includes shipping and insurance to continental US. PM, email, or text for more info.
    33 Feedback Rating on LS1Tech
    1452 eBay Feedback Rating
    Brandon
    630-209-1860
    jbrandon3@yahoo.com
    Fast EZ-EFI 2.0 - Complete (New in Factory Sealed Box)
    Part Number: FST 30405-KIT
    $1385 Shipped
    Info
    Easy LS-Engine Swaps; No Complicated OE-Harness Re-Working or Costly PCM-Tuning
    FAST engineers have developed the simplest plug-and-play, self tuning engine control system on the market for the LS series of engines. The FAST EZ-EFI 2.0 LS Self Tuning Engine Control Kit is the easiest way to get your LS transplant up and running without the complex PCM flashing and harness reworking required with the stock unit. This kit features all of the advantages of the award-winning EZ-EFI 2.0 ECU, plus it includes the EZ-LS Ignition Controller and uses stock or aftermarket LS injectors, sensors and coil packs.
    Advanced Color-Touchscreen Hand-Held Can Replace Tach & Most Gauges
    Each FAST EZ-EFI 2.0 system utilizes an easy-to-use interface through the included touch screen hand-held and doesn't require a laptop or tuning experience. After initial setup, the hand-held can be used as a digital dash with the included suction cup window mount. The EZ-EFI 2.0 system actually tunes itself as the user drives, and because it keeps tuning, future engine upgrades are a breeze, meaning that expensive trips to the shop for simple tune changes are a thing of the past. A purpose-built, OEM-quality wiring harness is included in the kit as well. It features a clean, mesh wrapping that dramatically improves engine aesthetics over the factory harness. And with the included FAST EZ-LS Ignition Controller, the user can easily get running or has the option to adjust timing. This multi-port installation kit is compatible will all LS-based car and truck engines and is designed and engineered by FAST. The EZ-EFI 2.0 LS Self Tuning Engine Control Kit is made in the USA, features a limited lifetime warranty and is backed by the industrys most extensive technical support team. If converting from carburetor, requires fuel system to be purchased separately.
    • Self tuning EZ-EFI gets you up & running quick & EZ; No laptop or tuning knowledge necessary
    • EZ-LS Ignition Controller offers no tuning quick setup option as well as custom tuning via hand-held
    • Hand-held displays up to 20 live-data readings/sensors; various dash display options
    • Limited Lifetime Warranty & backed by the industry‚Äôs most extensive tech support team
    • Modern, mesh-wrapped wiring harness replaces ugly, complicated stock harness
    • 100% designed & engineered in house by FAST staff
    • Uses OE/stock-style, LS sensors, ignition, & injectors
    • Hand-held start-up gauge screen is user selectable
