fast xfi wiring question
Discussion in 'High Tech Retrofits' started by jrobin9, Aug 18, 2006.
  1. jrobin9
    jrobin9 Veteran Member Lifetime Gold Member
    348
    Aug 22, 2001
    Monticello GA
    I have a xfi with msd 6al, msd crank trigger and msd dist (1 reluctor tab). Where is the 6al wired into the loop?
  2. Rick WI
    Rick WI Veteran Member
    10,400
    Jul 9, 2001
    Madison, WI
    The points wire off the harness connects to the points wire in the 6 box. Everything else wires up like a standard MSD box.
