Fel Pro head gasket question...
Discussion in 'High Performance Modifications' started by Dan's 77 Camaro, May 4, 2009.
  1. Dan's 77 Camaro
    Dan's 77 Camaro New Member
    27
    Oct 3, 2008
    St. Louis, MO.
    just wondering which side goes up on a fel pro sbc head gasket? no instructions and I don't want to make the mistake of installing upside down.I assuming the striped side goes up. also do you install them dry? thanks
  2. CNC BLOCKS
    CNC BLOCKS Veteran Member
    1,611
    Oct 11, 2004
    NORTHEAST
    The stripes and the writing should face upward.
  3. kenny77
    kenny77 Veteran Member Lifetime Gold Member
    2,681
    Jul 31, 2001
    Ft. Lauderdale, FL
    Look really close and you will see "UP" embossed on one side of the head gasket
  4. dcozzi
    dcozzi Veteran Member
    2,111
    16
    May 1, 2002
    Phoenix, AZ
    And if you install them "upside-down"????
  5. nagrom28
    nagrom28 Veteran Member
    361
    Oct 24, 2008
    Wilton, Iowa
    when i was racing on the dirt, my engine builder put them on upside down for steel heads and right side up for aluminum heads. if you put them on upside down, there should be no problem.
