Fender rolling
Discussion in 'Body Restoration' started by VSTOL, Nov 10, 2019 at 11:01 AM.
  1. VSTOL
    VSTOL VSTOL
    24
    Sep 21, 2019
    I am looking for tips for the best way to roll the rear fender lip. I have viewed many "how to's" on Youtube I and the Eastwood roller looks to be as god as any one piece. The paint is very good so I am very cautious. Thanks Kevin
  2. badazz81z28
    16,579
    434
    Las Vegas, NV
    Heat and slow. I used a baseball bat between the tire and the fender. The Eastwood tool does not work with a narrowed housing.
  3. VSTOL
    VSTOL VSTOL
    24
    Sep 21, 2019
    Thanks I have a stock width housing.
  4. Zspoiler
    Zspoiler Veteran Member
    3,208
    250
    May 6, 2012
    Federal Way, Washington
    I used the baseball bat method on mine,
  5. VSTOL
    VSTOL VSTOL
    24
    Sep 21, 2019
    I will pass on using the bat :)
    dave@ztech likes this.
  6. Scott51
    Scott51 Veteran Member
    622
    69
    Jan 2, 2012
    New Zealand
    If your paint’s good and you really don’t want to mess it up get a pro to do it. Is super common and relatively inexpensive in the import scene and there are companies out there that will come to you if necessary
  7. badazz81z28
    16,579
    434
    Las Vegas, NV
    I think you’ll have a hard time here. Imports have single layer, thin metal. You could roll it easily. The overlapped metal on a sec gen wheel well is tough. You will surely have risk or cracking new paint. Not sure someone would take this on...or give you that disclaimer. In that case, I rather mess my paint up my self.
  8. CorkyE
    10,266
    430
    If you're going to roll it, it's like a bar of Ivory soap, 99 44/100% sure the paint will crack. That's my experience.
  9. Coadster32
    1,624
    130
    Oct 2, 2013
    Milford,CT
    I've never done it myself...but have heard time and time again to roll it, then paint it. (Or was that roll it, then smoke it).:crazy::crazy:
