Fi Tech issue
Discussion in 'High Tech Retrofits' started by wiseryder, Jul 22, 2018.
  1. wiseryder
    2,072
    42
    Sep 11, 2004
    belding,mi USA
    Hey guys that have these things, Ive had mine on for almost 2k miles,thing has worked flawlessly,
    Driving home the other night It all a sudden devoleped a flutter on acceleration.
    it runs and drives but wont run hard anymore,
    I thought at first it was a ignition problem, tried a different dist.
    I gotta think its a fuel problem, but I dint know what to check, everything looks the same on the handheld as before ,
    anybody got any thoughts on this? I need some help here guys
    Thanks Scott
  2. redriderjf87
    redriderjf87 Veteran Member
    131
    11
    Jan 23, 2016
    Quad Cities, IL
    I'd pick one of the handheld datalog screens and log a drive where you can re-create it. My personal guess is that it's going lean right when you step on it and then the ecu is compensating after the fact and flooding it rich for the next few seconds. If that's the case then it may be a matter of seeing if you're not holding 58 psi for some reason.
    Or otherwise, I have a thread I posted on some software issues I found that was causing me fuel delivery issues for the 2 years I've owned mine. But yours being just a recent issue makes me wonder if something physically changed. Do you have a FCC or in-tank pump?
    Unfortunately FiTech can't monitor the fuel pressure directly but it sounds like it's not too bad to hook up a transducer to log separately worst case.
    Feel free also if you want to attach a log csv file.
  3. wiseryder
    2,072
    42
    Sep 11, 2004
    belding,mi USA
    I kinda hear ya, but this car will rev right up high in park.
    I've changed all ignition pieces, no change, it happens under load
    Im stumped, dont make sense
  4. wiseryder
    2,072
    42
    Sep 11, 2004
    belding,mi USA
    I forgot to add , Has a inline pump from FiTech
  5. 79T/Aman
    79T/Aman Veteran Member NastyZ28 Sponsor NazstyZ28 Sponsor Lifetime Gold Member
    2,438
    123
    Oct 7, 2004
    Dickson TN.
    with no load it will rev fine even if your fuel pressure is low, as stated above check your fuel pressure Chinese parts fail for no reason.
  6. wiseryder
    2,072
    42
    Sep 11, 2004
    belding,mi USA
    yep, Im thinking so too. Im going to buy a new pump so I can find out
    Theres no way that I know of to check FP on these things
  7. earnhardtgm3
    earnhardtgm3 Veteran Member
    2,835
    33
    Dec 18, 2007
    Camaro Country,GA
    Did you check your fuel pre filter before FITech. If you installed one.
  8. wiseryder
    2,072
    42
    Sep 11, 2004
    belding,mi USA
    Yes I did, Fitech told me to remove it and drive it . to see what the AFR's do, they went up. New tank with in tank pump will be here today
    John Wright likes this.
  9. 8pack
    2,575
    141
    Aug 29, 2007
    Pittsburgh, PA
    Go to Chevelles.com in the EFI section and see what they have to say. Those guys seem to have a lot of experience and know most of the issues that occur with the Fitech Units
  10. Joekool
    Joekool Veteran Member
    5,917
    34
    Feb 4, 2002
    Hollister CA USA
    Fuel trim is your best indicator of what the computer is trying to do. If it's negative then you have a rich condition, if it's positive you have a lean condition.
    I'd pull the spark plugs and see if any are fouled and what color the electrode has (gray, light brown, black).
