Fi Tech: New TBI Fuel Injection System
Discussion in 'High Tech Retrofits' started by Enroute, Jul 27, 2015.
  1. BonzoHansen
    19,367
    734
    Jun 1, 2005
    Scott from Hamilton, NJ
    Longevity is my concern
  2. Fbird
    3,884
    602
    Feb 12, 2011
    atlanta, ga
    the "cant use timing feature with HEI" ..... thinking this is MOOT!
    Should be able to simply eliminate the module. Use the mag pickup (2 wires) and send it to the ECU. Pin the advance plate (#8 nut-bolt IIRC) then hook up the coil just as you would any EXTERNAL coil.
    In fact this is straight out of MSD instructions... IIRC. When adding a 6al box to hei. You can either keep the module or bypasss it.
  3. Cataldo
    Cataldo Veteran Member Lifetime Gold Member
    2,649
    Jan 16, 2005
    San Bernardino, California, U.S.A.
    You are correct with the MSD box, and I would assume the same for this FI.
  4. Cataldo
    2,649
    Jan 16, 2005
  5. DENALI
    DENALI Veteran Member
    1,096
    19
    Nov 4, 1999
    Sonova Beach
    I am leaning towards this system for my daughters 78 TA that we are doing an LS swap in. Another benefit, for her car anyway, is it will simplify retaining the shaker.
  6. 72406
    72406 Veteran Member
    620
    Jan 22, 2001
    Lake Stevens ,WA
    New photos
  7. ProjectCam76
    ProjectCam76 Veteran Member Lifetime Gold Member
    275
    Aug 10, 2015
    Birmingham, Alabama
    That looks good! The pictures I've seen of that new Holley Sniper they're coming out with appears to much cheaper made in construction.
  8. Enroute
    Enroute Veteran Member
    695
    Nov 1, 2001
    S. Ontario
    Awesome purchase
    That does look good !!! And the fun begins :happy: :happy: :happy:
    Have you decided on the fuel delivery setup?
  9. JKC
    JKC Veteran Member
    104
    Jul 12, 2014
    Knoxville Tn
    I'm ready to bite and FiTech is the way I'm going so wish me luck I ordered the new go 800 with command center.
  10. 72406
    620
    Jan 22, 2001
    Lake Stevens ,WA
    its a solid. Looks well built
