Fiberglassing speaker enclosures-pics
Discussion in 'Interior Restoration' started by Chuck71RS, Apr 2, 2016.
  1. Chuck71RS
    1,440
    179
    Nov 24, 2012
    Houston, Texas
    I want to apply fiberglass to the wood enclosures and vertical side of the plastic speaker grill
    - - - Will fiberglass strengthen the wood enclosure seams and the wood-plastic grill seam?
    - - - To apply fiberglass to the plastic speaker grill, is a particular resin-hardener needed ?
    I have never used fiberglass. Suggestions how to go about it would be appreciated.
    Do not want to apply fiberglass to the door panel. Want the grill and enclosure removable. Once the exterior is cured will remove, take out the speaker and put a layer along the inside seams
    Below is one of the lower door panels for my 71 with a 4" speaker. I just finished making wood enclosures for all four sides for both panels
    The wood edge that contacts the plastic grill will be glued (Loctite Plastics Bonding System)
  2. Batman
    Batman Administrator Staff Member Lifetime Gold Member
    8,673
    Dec 13, 1999
    Mission Viejo, CA, USA
  3. Project-Z28
    Project-Z28 Member
    81
    Apr 22, 2012
    Newfoundland
    I have built some custom speaker and sub boxes . Now im not saying my way is right but use mdf instead of plywood. It doesn't absorb the sound and a little easier to work with. For what your building just the mdf and some carpet or material and shaping of the mdf should do the job . Use pl preium to put it together with the help of a nailer . Fiberglass is easier to work with on a big project if you haven't done it before .
