First Time LSX swap review
Discussion in 'High Tech Retrofits' started by jb451, Aug 5, 2014.
  1. DoTheDew
    DoTheDew Veteran Member
    899
    Mar 2, 2010
    Leduc, Alberta
    Looks good!
  2. sbca96
    sbca96 Veteran Member
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
    I cant dyno the LT1 swap until the exhaust is flowing correctly. I wanted to also
    dyno the Avanti, but .. with my luck it would explode.:roadkill:
    Sounds good on the dyno once all the fart machines and firetrucks go by. What
    the heck is that on the right hand side of the video wiggling the whole time??
    Tom
  3. jb451
    jb451 Veteran Member
    861
    Jan 17, 2011
    Mesquite, Texas
    Honestly Tom, no clue. I don't remember having anything on my hand or in front of me. My girlfriends hair maybe?lol
    What up with the exhaust? Not routed right or something?
  4. sbca96
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
    Could be her hair ... that makes sense.
    Oh, the routing is good, its just that when I was getting it ready for smog, it still
    had the stock 1978 exhaust on it. I made the Y-pipe to single 3 inch for the CAT
    as required since its a 1994, but the stock exhaust was only a 2 inch single pipe.
    I made a reducer/adapter to bring the 3 inch down to 2-1/4 to bolt up to pass in
    the smog referee testing. Then I found the transverse muffler was in the way to
    run the rear sway bar and the EVAP equipment. I got a Magnaflow exhaust for a
    1978 Camaro, but it uses only a 2-1/2 union, so I left the reducer/adapter. I did
    some calculations and found that 3 inch tube down to 2-1/4 is a 43% reduction
    in area! I did not think it was THAT much. That explains why power drops off so
    rapidly at around 4 thousand rpm.
    That said .. it still amazes me we got a 0-60 in 6.1 seconds with a 2.41 diff and
    two people in the car.
    http://www.nastyz28.com/forum/showthread.php?t=259226
    Tom
  5. jb451
    861
    Jan 17, 2011
    Mesquite, Texas
    So for anyone else in the US, the remedy would be to up the exhaust size (and remove the CAT completely), but seeing as how you have to deal with the smog stuff, how are you going to tackle that? Are you going to toss that 3" Y on and ditch that reducer still?
  6. sbca96
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
    The CAT I used was a high flow, the claim is about 4 hp loss, I can live with that.
    The Y-pipe, if you have seen my thread is all cleaned up inside, ported, my flow
    is directly restricted by the reducer/adapter. I left it on because the Magnaflow
    CAT back bolts up to it. I brought it to a local muffler shop and asked the guy if
    he could remove it and cut off the front of the Magnaflow to a point equal in the
    area of a 3 inch tube, but he told me that he felt it wasnt harming anything. That
    did not instill much confidence in having him do my Avanti exhaust (he asked if I
    would let him do it a while back).
    The plan is (once the oil leak is solved in the '99 Camaro SS) to bring the '78 into
    the garage, take some measurements of the Magnaflow "Y" to see at where it is
    the correct area to increase flow, and design a better flowing connection.
    Had I used a 1995 LT1, I could have used two CATS. Or had I used a B-body as
    they had two CATS in 1994.
    Tom
  7. Iknow2
    Iknow2 Veteran Member
    137
    Aug 6, 2014
    Houston, Texas
    did you remove or relocate the a/c compressor or the power steering?
  8. jb451
    861
    Jan 17, 2011
    Mesquite, Texas
    No A/C, and the alt and PS pump stayed in their factory truck configuration!
  9. Iknow2
    137
    Aug 6, 2014
    Houston, Texas
    thanks ^^^^^
  10. DBS
    DBS Veteran Member
    367
    14
    Sep 24, 2014
    Belzoni MS
    what kind of mpg you getting
