Flasher knob for a 1970 (see pics)
Discussion in 'Interior Restoration' started by 67johnny, Nov 1, 2018.
  1. 67johnny
    67johnny Veteran Member
    198
    Apr 14, 2016
    vancouver
    Hey all!
    Assembly of the steering column has me looking at the flasher actuator knob and as per usual, I will try to use the correct one when I can.
    I have two to choose from and they both have different fonts.
    I am thinking they were both acceptable. Thoughts?
    This is a Norwood car if it matters and I am just looking at this as a curiosity more than anything else.
  2. 70lt1z28
    3,473
    689
    Oct 3, 1999
    Beavercreek, Ohio, USA
  3. 70-camaro
    70-camaro Veteran Member
    2,428
    481
    Mar 25, 2010
    marietta ohio
    I am sure mine is black too.
  4. 70Znut
    70Znut Veteran Member Lifetime Gold Member
    180
    78
    Feb 5, 2016
    Sarasota,FL
    Here a pic of my 70 Norwood flasher. Looks like the bottom of your two pics
  5. COPO
    18,024
    853
    Here's my Norwood 70 Z28 orig 4 way flasher knob.
  6. badazz81z28
    17,107
    548
    Las Vegas, NV
    As soon as my IDIDIT shows up...My original 1970 Column with flasher will be for sale.
  7. 67johnny
    198
    Apr 14, 2016
    vancouver
    Looks like what I have been seeing.
    A mix of chrome and black so... now I am back to square one on this.
    Did they out-source the column assembly pre the installation by the assembly line workers or... ?
    Such an easy item to replace by people that may have thought the chrome one looked a bit fancier.
  8. 70lt1z28
    3,473
    689
    Oct 3, 1999
    Column assembly was not out-sourced. They were assembled by either the Saginaw steering division or by one of the Delco divisions. GM was very vertically integrated back in the 60's-70's and they wouldn't have let an assembly as important as a steering column to a third tier supplier. By this time steering columns were an important part of the safety systems due to being collapsible in front end collisions. Third tiers may have actually molded the knob but did not assemble the column.
    Pretty sure the chrome knob on the Camaro was done in 68. 69's had black knobs also. May have coincided with the key moving to the column.
  9. John Wright
    14,712
    215
    Aug 9, 2002
    Rustburg, Va
    I think the one on my 70 is black too....but to be honest, I'll have to look when I get home to be 100% sure.
  10. TommyRS70
    TommyRS70 Veteran Member
    1,200
    102
    Jan 31, 2004
    KY
    Since firebird and camaro columns are interchangeable, wonder if the firebirds had the chrome flasher knobs?
