Flex fuel sensor location.
Discussion in 'High Tech Retrofits' started by CAMeeks, Aug 27, 2018.
  1. CAMeeks
    CAMeeks Veteran Member
    686
    34
    Jan 5, 2014
    Deer Park, TX
    Going to be mocking up the fuel lines soon and need a location where to mount a factory flex fuel sensor.
    I have the LS3 with the tanks efi tank. So I will have a short run from the tank to the reg/filter then a run from that to the front of the car. The reg/filter has a return on it. I'm thinking of having the filter no more then a foot or two away from the tank and would like the sensor back there also.
    Mike-78 Z-28 likes this.
  2. CAMeeks
    686
    34
    Jan 5, 2014
    Deer Park, TX
    Has anyone setup flex fuel here?
    Can it be on the return line from the filter/regulator or does it need to be on the feed line going to the front. I'm running 1/2 in feed line incase I want to do future mods but the flex fuel sensor is 3/8.
