Floor mounted gas pedal support bracket 1970 Camaro Z28
Discussion in 'Swap Meet Section' started by Rich Gershman, Jun 8, 2017.
  1. Rich Gershman
    Rich Gershman New Member
    15
    May 21, 2017
    Does anyone know of or have a floor mounted gas pedal support bracket. This support mounts to the floor and the two stud balls come through this support and the accelerator pedal then snaps onto the studs. It is listed in the assembly manual for 1970 z28 the support is #7 on the page. Thanks, Rich
  2. Zspoiler
    Zspoiler Veteran Member
    3,297
    269
    May 6, 2012
    Federal Way, Washington
    Have you checked the Camaro restoration parts suppliers like Classic Industries .and others on this site and the Net. /
  3. Rich 1970 Z28
    Rich 1970 Z28 New Member
    Jun 8, 2017
    I have scoured the internet and all of the aftermarket companies like Classic Industries.... no luck.
  4. Bandit723
    Bandit723 Veteran Member
    3,148
    464
    Oct 1, 2016
    Waupaca WI
    Try Modern Chevrolet they are out of Winston-Salem NC. Have had good luck with them finding parts. 800-334-0165
  5. Rich 1970 Z28
    Jun 8, 2017
    Thanks I will try them.
  6. restore-z28
    restore-z28 Veteran Member
    423
    69
    Jul 4, 2010
    Vancouver, BC
    Bandit723 likes this.
  7. Rich 1970 Z28
    Jun 8, 2017
    Thanks
  8. 70-camaro
    70-camaro Veteran Member
    2,428
    481
    Mar 25, 2010
    marietta ohio
    I agree about modern Chevrolet. I saw one on eBay a while back too.
  9. badazz81z28
    17,107
    547
    Las Vegas, NV
    Reproduction in EBay
  10. 70-camaro
    2,428
    481
    Mar 25, 2010
    marietta ohio
    No, it had surface rust and was from an early 2nd gen, so the fit would be right.
