Floor Pan Advice
Discussion in 'Body Restoration' started by NeoNeuro, Aug 30, 2015.
  1. NeoNeuro
    NeoNeuro Veteran Member
    188
    Aug 4, 2014
    Panama City, FL
    Hi Everyone,
    I pulled the carpet out of my 78 yesterday and was disappointed to find rust in the passenger floorpan. To me it doesn't seem terribly bad. One hole smaller than a pencil. I banged on the floor around the hole and it seems pretty solid. What do you think? Is this worth cutting out and replacing or can it be patched? What would you recommend for a patch?
    BTW, what is the black stuff that they used to seal the seams? Where can I get it or is there a better substitute? Thanks.
  2. czizza
    czizza Veteran Member
    1,009
    53
    Jan 8, 2004
    N. Massapequa, NY, USA
    Check from underneath ... the correct way is to cut a patch and the quick way is if the holes are that small I would fill it with a welder and then use POR15 to neutralize the rust.
  3. 1971SS
    1971SS Veteran Member
    724
    Feb 5, 2011
    eastern NC
    Cut that hole out and get a 16ga sheet metal patch mig welded in. Also, peel that black seam sealer off and clean those areas, trouble in the making there with rust already present. Clean that metal good to shiney metal...
    that black stuff is seam sealer...available at most parts stores...
  4. David79Z28
    1,279
    40
    Oct 22, 2009
    Greenville, TX
    I used 3m seam sealer. It's held up great!!
  5. perkalator
    perkalator Veteran Member
    1,025
    89
    Aug 27, 2014
    kennewick wa
    Clean with by sanding with 80 grit and then treat with acid rust nuetralizer or sand blast all rusty areas if its just a small hole spot weld it. Make sure if you use acid to nuetralize and clean before painting. If you the area expands after cleaning make a small patch and weld it in. I wish my floors looked like that.
  6. NeoNeuro
    188
    Aug 4, 2014
    Panama City, FL
    Thanks everyone for the advice. I'll raise it up tonight and see what the bottom looks like. I'm probably going to play it safe and cut it out and replace with new metal, but want to see whole picture first. Thanks again.
