Floor Replacement and Torque Box Locations
Discussion in 'Body Restoration' started by Sam's Z, Nov 30, 2019.
  1. Sam's Z
    Sam's Z New Member
    11
    Jul 14, 2019
    Soon I will replacing my floor with a new one piece from AMD. I did get the one that has the braces and new torque boxes. I'm still unsure if I will use the new torque boxes, but probably will. Anyway I plan on taking alot of measurements to ensure they go back in the same locations. One thing that has me puzzled is a small gap between the flanges of the original torque boxes and the floor pans. Most that I have seen fit flush. What are you guys thoughts? Thanks
  2. Scott51
    Scott51 Veteran Member
    625
    73
    Jan 2, 2012
    New Zealand
    Mine were like that on one side so I closed up the gap with the help of a hammer and sheetmetal screws then plug welded from the inside of the car every 2”
    Sam's Z and hubedobeedo like this.
  3. hubedobeedo
    hubedobeedo 3rd times a charm
    455
    140
    Jul 18, 2013
    Huntertown,IN
    that's a really good way to deal with that.
  4. budro6968
    budro6968 Veteran Member
    3,204
    507
    Apr 2, 2016
    Jax Florida
    Just a little massage.
  5. badazz81z28
    16,716
    464
    Las Vegas, NV
    That’s assembly line built. Lots of little things like that all over these cars
  6. Sam's Z
    Sam's Z New Member
    11
    Jul 14, 2019
    Thanks guys. Glad to know others have had similar situations with theirs. That was what I was hoping to hear. I feel ok now, knowing I can use these as a guide for measurements prior to reassembly. They will fit alot better when they go back.:)
  7. thesalboy
    thesalboy Veteran Member
    350
    111
    Mar 25, 2017
    Los Angeles, CA
    If you do weld-in subframe connectors, like the SFCs from DSE, you'll have a chance to close those gaps up, like I did - mine looked just like yours.
  8. 70RamAirIII
    70RamAirIII Pontiac-aholic
    47
    8
    Jan 10, 2005
    Calgary, Alberta
    wow - that gap is crazy!
    Granted I have never stopped to look at cars in this area (other than the two I have owned), but sheesh...
    I would have never guessed I'd see gaps that big - I guess on the up side, they are the same on both side!
    This reminds me of a 'Cracked' poster my uncle (10 years my senior) had on his wall when I was growing up...
    It showed the 'Cracked' mascot with an A-OK stamp at the end of an assembly line, and (iirc) the car he just stamped was falling apart...
    this is the magazine, obviously not the picture I recall:
    I wonder if that's caused from the rear floor pan being a bit forward from where it should have been!?
    I am with Scott though, I'd be incline to massage it, and close the gap.
