for guys running stealth ram efi setup
Discussion in 'High Tech Retrofits' started by jrobin9, Feb 9, 2006.
  1. jrobin9
    jrobin9 Veteran Member Lifetime Gold Member
    348
    Aug 22, 2001
    Monticello GA
    I'm putting together a stealth ram, xfi setup. Stealth ram says use gm small cap efi distributor. I have an 8360 msd lying around. What you guys running? Can I get by with using the 8360 (if it will fit) or should I go with the efi dist?
  2. Rick WI
    Rick WI Veteran Member
    10,400
    Jul 9, 2001
    Madison, WI
    The small cap MSD works great. You do have to cut the reluctor wheel tabs off except the one just prior to #1 firing. That is you injector sync signal.
  3. f-body
    f-body Veteran Member
    1,674
    Feb 1, 2000
    Dallas
    Is this a Xfi as in crossfire efi. i know the stealth ram uses a single plane with a cross ram top. If I am correct here is a sight that deals with the crossfire efi, stealth ram, and factory cross ram carbed intakes using crossfire throttle bodies on a custom top plate. You will have to register to view but it has great info look under alternate induction for mods to Xfi intakes.
    http://www.crossfire.homeip.net/
