? for those who have installed the NPD dash pad
Discussion in 'Interior Restoration' started by 7dcamaro, Oct 23, 2019.
  1. 7dcamaro
    7dcamaro Veteran Member
    366
    Apr 10, 2012
    Warner Robins, GA
    Just got my NPD dash pad today for my 70...it looks great. I've read all the threads on this forum about this pad and know about all of the known installation issues. But I haven't seen anyone comment about the pre-drilled mounting holes that are in the pad and whether they work with the original fastener types and sizes or not. I say that because the holes look too big to be able to use the original fasteners which is want I want to do....I bought all new OEM fasteners for the entire dash from AMK. For those that have installed the pad, do the original OEM fasteners work? My main concern are the holes that are used to attach the gauge cluster housing to the dash pad and the holes used to attach the lower plastic dash panels to the bottom of the dash pad. Any info would be appreciated.
  2. twestrup
    twestrup Veteran Member Lifetime Gold Member
    138
    44
    Aug 22, 2018
    Hollister, Cal
    Look at this video, pretty good:
  3. mrfleet12
    mrfleet12 Veteran Member
    322
    88
    Aug 8, 2014
    West of Chicago IL
    My fasteners worked fine and my cluster (Dakota Digital) fit without issue.. The area to pay attention to is where it meets the metal portion on top. I didn't spend enough time there to get a great fit.
  4. 7dcamaro
    366
    Apr 10, 2012
    Warner Robins, GA
    I've seen that video but it doesnt answer my question. It appears they're using the stock hardware in the video.....but with respect to the holes used to mount the heater control panel under the steering column on the pad that I have, I can take the stock screws and stick em in those holes and pull em right back out by hand....so I can't see where the stock size OEM screw is gonna work.
  5. rotinrob
    rotinrob Member
    34
    16
    Oct 2, 2018
    I used a mix of original and AMK fasteners in my dash with no problems except it seems like on the ash tray side there wasn't a boss for one of the fasteners. I will need to look but I am certain that was the case. Early build car at 01C so maybe that area changed.
