Frame Connectors 1970
Discussion in 'Body Restoration' started by patpkk, Apr 14, 2012.
  1. patpkk
    patpkk Veteran Member
    168
    Jul 21, 2008
    Have a very clean 1970 shell and do not want to cut up the floor in any way or shape. What product do we suggest to link the frames on this car that is just bolt in. Any suggestions guys? Pat
  2. grzewnicki
  3. patpkk
    168
    Jul 21, 2008
    Thanks for info, have you used this on any of your cars? Pat.
  4. wardracing
    wardracing Veteran Member
    637
    Jan 19, 2011
    columbus,ohio
    their are a lot of people here that have his products or similar, i suggest that you weld them in and use solid bushings, that will be the best way to tie the front to to the back.
  5. mjoc
    mjoc Veteran Member
    3,497
    Apr 29, 2003
    Sherman Oaks, Ca
    I bought bolt in subframe cannectors years ago don't remeber the company. but after I bolted them in I welded them in place.
    Michael
  6. wayback
    wayback Veteran Member
    PTFB, Alston, and Competition Engineering make bolt-in SFCs that will fit your car. The PTFB design is better as there is little loss of ground clearance compared to the other two. I have Jegs SFCs in my '78, which are similar to the CE design. Originally installed in 2002, I removed them last summer for repainting when installing new leaf springs. They were never welded in and there was no sign of bolt-hole elongation after 9 years.
    http://www.pro-touringf-body.com/chassis_components.html
    http://www.cachassisworks.com/p-1409-camaro-70-76-firebird-70-76-f-body-subframe-g-connectors-for-leaf-spring-rear-frame.aspx
    http://www.competitionengineering.com/catalog/CategoryDisplay.asp?CatCode=11001
    :bowtie:
  7. 73 L92
    73 L92 Veteran Member
    126
    Apr 4, 2012
    Carlos, MN
    On my 73 I did the PTFB subframe connectors. Bolted to the front sub frame and back frame rail not welded to the back until I had the front end aligned all four wheel to make sure the front and rear wheels were "square".
    Also did the solid bushings from DSE. Worked great. Fender gaps were good.
    Only short drives so far but very solid.
  8. patpkk
    168
    Jul 21, 2008
    Thanks for the input guys. Appreciatee it.
  9. 1971camaro383
    1971camaro383 Member
    38
    Aug 17, 2010
    long island NY
    I just installed and bolted in the PTFB subframe connectors..I'll drop pictures tomorrow for you... Once I drive I'll let you know my feedback... Once the rain brakes..
