Front Brakes Dragging
Discussion in 'Troubleshooting & Diagnosis' started by 81 Sport Coupe, Oct 6, 2016.
  1. 81 Sport Coupe
    81 Sport Coupe Veteran Member
    246
    Nov 27, 2012
    Batavia, NY
    I'm working on my buddies 69 Camaro, drag car with line lock and I just did a front disk brake conversion kit on it. took it down the road and the front brakes are locked up, I know its not the calipers and the line lock solenoids because I undid the brake lines at the proportion valve and the brakes are free, any ideas?
  2. Hey G
    Hey G Veteran Member
    519
    Mar 18, 2012
    SC
    Is it a drum brake car? Did you change the master cylinder? The drum brakes require 5-10psi residual pressure and the valve is inside the MC (in most stock MC). Hope this helps.
    G
  3. COPO
    17,718
    691
    Did you adjust the rears yet or do they work at all?
