Front fender patches?
Discussion in 'Body Restoration' started by MintaTrask, Nov 13, 2019.
  1. MintaTrask
    MintaTrask New Member
    Nov 13, 2019
    Hi there,
    I want to put fender patches on my 72 probally on both sides, i was looking at the ones at momentum and have a question, on the fender it looks like there is 2 pieces sandwithced together is this right? and if so are the patches just new skin sections? how do i get the 2 pieces seperated?
  2. BowHunter
    BowHunter Veteran Member Lifetime Gold Member
    956
    17
    Nov 12, 2004
    Wappapello Mo, USA
    Skins
  3. budro6968
    budro6968 Veteran Member
    3,269
    522
    Apr 2, 2016
    Jax Florida
    Go on you tube to check out panel replacement. Tons of Vids.
  4. Jeep43
    Jeep43 Veteran Member
    1,298
    48
    Mar 30, 1999
    Connecticut
    The thing about fender patches is they don't include the very bottom most flange (horizontal) where the the fender bolts to the body. If that part of your fender is rotted, you have to fabricate....
    hubedobeedo and giggity like this.
  5. bodymanbill
    bodymanbill Veteran Member
    1,306
    666
    Feb 1, 2007
    South Park Pa
    6845885D-7324-4AEF-AB68-276EF17EC454.png You are better off buying a cheap after market fender and cutting the bottom off that way u get the inner brace that is always rotted. The rust gets in between the two and rots both pieces.
    Sam's Z, checkmate201 and hubedobeedo like this.
  6. giggity
    giggity Veteran Member
    947
    96
    Mar 18, 2013
    Pearland, texas
    All patches suck...your better off buying AMD fenders and using them or cutting bottoms off.
  7. 70lt1z28
    3,413
    681
    Oct 3, 1999
    Beavercreek, Ohio, USA
    bodymanbill and hubedobeedo like this.
  8. hubedobeedo
    hubedobeedo 3rd times a charm
    487
    152
    Jul 18, 2013
    Huntertown,IN
  9. Scott51
    Scott51 Veteran Member
    625
    73
    Jan 2, 2012
    New Zealand
    The outer skin is spot welded to the inner brace, so drill out the the spots and carefully pry the two pieces apart (air chisel works well)
    If the wheel arch area is salvageable it’s pretty easy to make a simple patch for the lower section of outer skin, or take a template to a sheetmetal shop and they can bend up a piece for you (no compound or convex curves)
  10. Chuck71RS
    1,477
    187
    Nov 24, 2012
    Houston, Texas
    I repaired both of my fenders laying a patch panel on the surface about two inches above the lower body line. Used a die grinder and cut out the bad metal and the right angles off the patch front and rear. Used 3m metal bonding adhesive and clamped. Die grinder smooth the front and rear edged. On the top edge put a slight taper on the patch. Applied Dynaglass along the seam then filler. After the primer, high build, and paint there are no visible signs of the repair
