Front Sway bar
Discussion in '1970 - 1973 Specific' started by falc, Sep 24, 2019.
Tags:
  1. falc
    falc New Member
    Sep 24, 2019
    I am restoring a 1970 Camaro that does not have a front sway bar. I ordered one online that is a 33mm, or 1.3". It seams really big for the car, and it does not appear that it will fit the original mounting holes or clear the idler arm. Any suggestions? I may be able to make it work, but it will be really tight.
    I appreciate the advice.
    Dan
  2. Zspoiler
    Zspoiler Veteran Member
    3,265
    264
    May 6, 2012
    Federal Way, Washington
    What do you plan to do with the car?.And what brand of bar ?Because mounting sway bars should be no issue mounting them .Since the car was designed to have the.
  3. 74Z28GC3
    74Z28GC3 Veteran Member
    1,695
    46
    Sep 1, 2000
    North Pole, Alaska
    It supposed to be 1" depending on what type of Camaro. The link below has information about the 1970 Camaro suspension. Hopefully, someone who has a 70 Camaro can comment on your post too. Welcome to the board and good luck on your restoration.
    http://nastyz28.com/camaro/70zsusp.html
  4. 70-camaro
    70-camaro Veteran Member
    2,389
    440
    Mar 25, 2010
    marietta ohio
    My base model Camaro came with a 15/16 front sway bar and no rear sway bar.
  5. flht99b
    flht99b Veteran Member
    268
    44
    Nov 28, 2014
    Knoxville, TN
    I have the OEM 1" front and 11/16" rear sway bars from my 1971 Z28 if you are interested.
  6. Gary S
    22,584
    808
    Aftermarket sway bars sometimes don't fit like factory ones. The 1970 Camaro had a 15/16" or 1" one depending on options. The 1970 Firebirds had similar ones, but the Trans Am optioned Firebird had a 1.25" front bar. The Trans Am 1.25" bar fits perfectly on the Camaro if you use the Trans Am brackets with it. That is what I currently have on my 1970 Camaro.
    Aftermarket ones might need some modification to fit. You have to figure that part out using the front bar you have.
  7. Zulu28
    Zulu28 Veteran Member
    287
    22
    Dec 19, 2013
    Vancouver, BC
    It's big because most likely it's a hollow tubular bar, get your money back and use a 1.25" front bar from a Trans am.
    70-camaro likes this.
  8. falc
    falc New Member
    Sep 24, 2019
    just normal driving on the street
  9. falc
    falc New Member
    Sep 24, 2019
    It is solid and very heavy. I think it is over kill.
  10. falc
    falc New Member
    Sep 24, 2019
    What do you want for it, and I am Raleigh, what do you think shipping would be.
