Front wheels rubbing
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Speed Happy '77, Oct 16, 2008.
  1. Speed Happy '77
    Speed Happy '77 Veteran Member
    122
    Oct 15, 2008
    Olympia, WA
    The previous owner installed wider tires on the car, but did nothing about suspension... now I have to be really careful on any dips and sharp turns or the tires rub on the wheelwell.
    My question isn't about the tires, just about good - and cheap - suspension alternatives.
  2. warped
    3,212
    Oct 20, 2003
    Sitting in my command bunker waiting for the zombi
    Without knowing more specific info it will be hard to say. There are several things that might account for the rub. If the tires are humongous, this could do it. Back space on the wheel would be another cause. If the front sits too low, the only way to fix it would be to install new springs. Let us know which of these you believe is causing the problem and we can suggest alternatives. Good luck.
  3. Nitroexpress
    Nitroexpress Veteran Member
    1,523
    Jun 1, 2005
    "Rochester" NY
    Pictures are also helpful!
  4. Speed Happy '77
    122
    Oct 15, 2008
    Olympia, WA
    I'll give pictures soon. The reason they're rubbing - well, the main one - is that the wheels are wider than stock, so they rub on the sides since they weren't built for that wide of tires. Also the (not sure exactly what it's called) rubber bumper stop is worn down and the tie rod end is ready to give too.
    I'm just kinda curious what I could replace it all with... what's good, what's cheap, etc.
    And springs would also be good. If I tighten the suspension, it'll help avoid rubbing. As I said, it's when I hit a big dip on the road, esp. going fast.
  5. dcozzi
    dcozzi Veteran Member
    3,151
    447
    May 1, 2002
    Phoenix, AZ
    PST is good and cheap.
    Most here will steer you towards Hotchkis which is great stuff as well. I think it is not much more either.
    You could piece it together with MOOG springs, Howe balljoints etc, save a little coin and spend more on the more critical components, but you probably will be better off doing a full kit. Sounds like the whole front end may be worn out.
    Definitely concentrate on the tie rod ends and stuff that can create a safety issue first.
  6. Twisted_Metal
    27,150
    1,046
    What size tires and how wide are the wheels?
    Do you know the backspacing on the wheels?
  7. thedude327
    thedude327 Veteran Member
    778
    Feb 21, 2004
    Brighton,Michigan U.S.A.
  8. heavy duty
    heavy duty Veteran Member
    529
    Sep 29, 2005
    Cactus Forest Arizona
    Good, and cheep? Ah, the irony.
  9. Speed Happy '77
    122
    Oct 15, 2008
    Olympia, WA
    Good point. I just want enough drivability to last me through the winter till I can get my daily driver back together, tell you the truth.
    The tires are Eagle GT II - P235/60R15 (I've never done anything with tires, so it's why I'm a little confused)
    Here's the link from Goodyear:
    http://www.goodyear.ca/goodyeartire...eadwidth=&aspectratio=&rimdiameter=&sidewall=
    If there's any information you need, I'll try and get it.
  10. 79T/Aman
    2,544
    177
    Oct 7, 2004
    Dickson TN.
    when does it rub it looks like you have a lot of roon around that tire
