fuel injected SBC vs gas mileage
Discussion in 'Engine Topic' started by dutch73camaro, Sep 5, 2017.
  1. dutch73camaro
    dutch73camaro Veteran Member
    162
    34
    Jan 7, 2016
    Beverwijk, Netherlands
    hi guys,
    i have a 73 camaro i'm building,
    i still don't have an engine so i'm reading a little bit about the options
    i prefer a fast SBC ( about 500 hp ) because of the prices / simplicity / and the amazing sound
    unfortunally the gas prices here are high in the netherlands, about 7 dollar a gallon ( €1.60 per liter ) and LPG is here about 90 cent in euro.
    is an fuel injected sbc also alot more efficiënt like an lsx engine ?
    and what about the bbc engine's ?
    the car is for me not a daily driver but a fun car.
    but i like to drive.
  2. ULTM8Z
    ULTM8Z Veteran Member
    9,087
    311
    May 19, 2000
    Los Angeles
    The transmission and gearing will play into it heavily.
    With 3.42 differential, overdrive transmission, lockup torque converter, and a ~400 hp 350, I'm pulling 26-27 mpg highway (cruising at ~2300 rpm at 70 mph). With a carburetor and the same transmission/rear-gear setup I was getting 21-22.
    Without the OD and carburetor, I could get about 15 highway (crusing around 3200 rpm at 70 mph).
  3. dcozzi
    dcozzi Veteran Member
    2,914
    323
    May 1, 2002
    Phoenix, AZ
    With a GEN 1 SBC, fuel injection and an overdrive transmission will be key elements for better mileage.
    An LS will likely be better for mileage.
  4. badazz81z28
    16,382
    406
    Las Vegas, NV
    Efficiency has many variables.
    #1 an engine that produces a lot of power requires fuel......Fuel is the stored energy (Meaning you want good mileage, drop the displacement and power)
    #2 Maximum utilization of the fuel turns into efficiency (Air to Fuel ratios is key). This is where computer controlled fuel injections helps. It doesn't stop there though, overall engine design helps fuel efficiency.
    #3 Engine RPMs, if you can drop RPMs of course the engine will burn less fuel (Gear ratios and Overdrive transmission)
    IMHO....If you want power and fuel efficiency, I would look into a small modern engine with Turbos. Other then that, if you want big cubes N/A, the LS will be more efficient then any design before it and its more then because it's fuel injected, its like I said design.
    A fuel injected SBC with good rear gears and an overdrive transmission will go a long ways, but not miracles. I could get about 15-18 with my 400hp SBC on a freeway road trip.
  5. dutch73camaro
    162
    34
    Jan 7, 2016
    i'm offcourse not looking at economy only,
    but now i can make a choice why not try to get it better
    i really want an overdrive transmission.
  6. Lowend
    14,933
    430
    Mar 25, 1999
    San Jose, CA, USA
    A properly done EFI engine will almost always do better on fuel economy than it's carburated counter-part.
    The knock sensor and timing control you get with EFI allow the engine to run WAY more lean than is safe with a carb and a weighted distributor.
    An LS will tend to produce better fuel mileage than a traditional smallblock mostly because the cylinder heads are so much more efficient.
    With the Crate engine LS3's getting so cheap, I think you're probably on close for overall costs with a 500HP EFI Gen 1 smallblock
  7. ULTM8Z
    9,087
    311
    May 19, 2000
    Los Angeles
    Yeah and it can make that kind of power while not sacrificing good street manners.
    If I had to start from scratch, I'd go LS in a heartbeat. But since my car is already set up for Gen 1 SBC and EFI, most likely I'll just do a 427 SBC later and get my big power that way... no need for the hassle of a LS swap when all I want is around 500 hp and 427 can do that easily.
  8. dcozzi
    2,914
    323
    May 1, 2002
    Phoenix, AZ
  9. ULTM8Z
    9,087
    311
    May 19, 2000
    Los Angeles
  10. Cooldawg
    Cooldawg Veteran Member
    196
    11
    Jun 3, 2014
    Angola, IN
    Don't care for the LS looks, but you probably wouldn't need to open the hood very often. My opinion:
    Driver: LS
    Looker: Gen 1
    Best of both: Gen 1 FiTech or Holley EFI
    I'm still struggling with a decision (and need to unsee that WP hybrid block, BTW), but aside from the carb in my Yamaha 9.9 kicker, I won't own another, EVER. I could buy another kicker for what I've spent having that PO... rebuilt.
