Fuel lines: Hard VS Braided Steel
Discussion in 'High Tech Retrofits' started by Aceshigh, May 16, 2011.
Fuel Injection up to 500hp which is better ??
  1. Steel lines
    31 vote(s)
    86.1%
  2. Braided steel rubber lines
    5 vote(s)
    13.9%
  1. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Which is better??
    I read NHRA requires braided steel lines ran along the frame rails.
    Found a site that wants $450-$550 for hard lines with a Corvette filter and compression fittings.
    I think I spent just $200 for my LS1 braided steel rubber lines with russell fittings and the Corvette filter.
    No idea how long it would take my lines to rot out though.....
    Or would bending my own regular steel lines be worth a shot ?
    http://www.inlinetube.com/
  2. camcojb
    camcojb Veteran Member Lifetime Gold Member
    2,600
    Jan 10, 2000
    Wilton, Ca. USA
    I always prefer hard lines along the frame. Normally bend my own but I just bought a mandrel bent line from Inline Tube for a friends 66 Fairlane Cammer EFI deal I'm working on; there are tons of bends on that particular car, felt like saving a bunch of time. I use a short section of braided or similar with AN fittings at the tank and up to the motor to allow for movement.
    Stainless hard line is my first choice but it is tougher to bend and less friendly if it needs to be tweaked a bit. Aluminum hard line is much easier to work with.
  3. ripcurl329
    ripcurl329 Veteran Member
    320
    May 14, 2008
    Fredericksburg, Va
    I have been checking out the stainless steel hard lines that Inline tube as well.
  4. sevitz5
    sevitz5 Veteran Member
    1,618
    Feb 27, 2011
    Middle Point, Ohio
    I just installed stainless hard line from "Fine Lines" on my 70. They cost me $99, and was worth every penny. They fit well and were bent well.
  5. JJFarmer
    JJFarmer Veteran Member
    2,447
    Jun 28, 2002
    Lenoir City, TN
    I used steel lines from Classic, then added compression fittings with barbed end to make the connections. I used fuel injection rubber hose and fuel injection clamps on the hoses to connect the pieces.
  6. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    There's actually fuel injection clamps??
    What do they look like ?
    So hard lines from the fuel regulator going up to the engine.
    Then 2 braided steel lines to the tank with 90* Russell fittings again.
    Or did you run hard lines there too JJ ?
    I know one flex line up front to the fuel rail. Just wasn't sure
    how to clamp it down, so this helps. :) Thanks.
  7. fbody_mike
    fbody_mike Veteran Member
    972
    Mar 24, 2009
    San Gabriel Valley, California
    Fuel Injection Hose clamps from Ideal.
  8. JJFarmer
    2,447
    Jun 28, 2002
    Lenoir City, TN
    Here is a clamp...
    They are cheap mail ordered. Also bought my fuel injection rubber hose from Rock Auto cause it's kind of high at the parts house. I used new factory metal tube front to back. Up front, I bent a 90 degree turn up to come out next to the AC dryer. Then added the barbed compression fitting, rubber hose and the adapter from rubber to a quick connect on the fuel rail. Same out back at the filter.
    Not the best picture but you can see it.
  9. BondoSpecial
    8,694
    Sep 20, 2004
    Southern Maryland
    Hard. Braided have a limited life span and unless you use teflon lined, will cause fuel odor. I would not use braided on the frame rails, only for flex and connection purposes at either end of the car.
    EFI hose and those clamps are okay but I would trust AN fittings and real hose ends a lot more than barb and clamps. Looks nicer too. I have done both ways.
    My 79 has stainless hard line front to rear that I bent myself. It does not bend nice and easy but it can be done. It connects to braided using compression to AN fittings.
  10. camarokidz28
    camarokidz28 Veteran Member
    188
    Apr 10, 2005
    Oak Forest, IL, USA
    you can make your own hard lines for pretty cheap... buy the line and get a tubing bender. we made em for my brothers car
