Fuel lines
Discussion in 'High Tech Retrofits' started by 408maro, Feb 9, 2016.
  1. 408maro
    408maro Veteran Member
    1,618
    Nov 27, 2008
    San jose,CA
    What's everyone running as far as fuel lines go for a fuel injection setup?
    I am serious about switching from carb to efi and trying to get everything locked down. As what I need for the swap.
    I know I'm going with a tanks inc tank and pump. Setup
    Also going with fitech efi.
    I know I have to switch the lines out, did you'll just take the line from tank to where it comes up in front and get a one piece solid line made or what was done?
    Thank you
  2. grasmo
    grasmo Veteran Member
    893
    Dec 21, 2005
    tallahassee, fl
    I ran braided stainless a few years ago. -8 I believe. although I don't currently have efi, I will use what is there if I do make the switch in the future. extremely easy to install.
  3. flak monkey
    flak monkey Veteran Member Lifetime Gold Member
    1,064
    Aug 5, 2011
    Norfolk, UK
    3/8 hard line from tank to bulkhead, then -8 braided from that to the fuel rails. The 5/16 hardline as a return.
    I modified my fuel tank to mount the pump on the bottom of it and put a sump on the bottom for it to draw fuel from.
  4. 408maro
    1,618
    Nov 27, 2008
    San jose,CA
    thank you for replying.
    where did you get the 3/8 hardline? was it pre made or did you have to take your old one off and get it made to match?
    thank you
  5. cvhu
    cvhu Member
    97
    Jan 18, 2012
    sarnia, ontario, canada
    i used plastic pvc fuel line from tank to fuel rail, it was around 60$ for 25 feet and all the fittings
  6. flak monkey
    1,064
    Aug 5, 2011
    Norfolk, UK
    I bought a coil of it and bent it up myself. Easy enough, just take your time.
  7. 408maro
    1,618
    Nov 27, 2008
    San jose,CA
    Thank you guys. 2 different ways of doing it i like it
  8. 76_TypeLT
    6,389
    144
    Jul 26, 2008
    Houston, TX
    I have toyed with the idea of running braided stainless the entire way but my gut tells me I should run hard to the engine compartment and then braided, like flak monkey did. I wouldn't want something on the road causing a break in the line.
  9. Goat
    1,913
    44
    Jun 7, 2001
    moncure, NC
    So where in the engine bay did ya'll terminate the hard line and transition to flex? Looking for a clean tucked up out of the way fuel line.
    Never worked on an LS - getting ready to install tank and run ss hard line and don't have the engine in yet to see where everything mates up...
    thanks.
  10. 76_TypeLT
    6,389
    144
    Jul 26, 2008
    Houston, TX
    I plan on using this "bulkhead" area to secure the end of the hardline and then run braided line to the fuel rail.
